Free Download VovSoft Bulk Barcode Generator 1.1 | 4.3 Mb
A barcode or bar code is a method of representing data in a visual, machine-readable form. Barcodes represent data by varying the widths, spacings and sizes of parallel lines. Linear or one-dimensional (1D) barcodes can be scanned by special optical scanners, called barcode readers.
Batch barcode generator
Vovsoft Bulk Barcode Generator is a powerful desktop application that allows you to create thousands of barcodes from plain-text data in batch mode. Instead of generating barcodes one by one, you can produce them all at once-saving time and increasing productivity, especially if you're mass-producing items or managing large inventories.
The software supports 85 different barcode types, including popular formats such as Code 39, Code 128, EAN-13, and UPC-A. You can export barcodes in various image formats, including PNG, JPG, GIF, and BMP, making it highly flexible for different use cases.
The best part of this program is that all processing is done completely offline. You have full control over your private data, and no barcode information is ever sent to the internet.
Whether you're in retail, manufacturing, logistics, or asset management, this easy-to-use tool offers a fast, reliable, and private solution for generating barcodes in bulk.
How to create a batch of barcodes
Open Vovsoft Bulk Barcode Generator program in Windows
Load any text file, using the menu: File > Load
Select any directory, using the menu File > Save all to folder
Then, the application will do the rest for you by creating image files and saving them to the specified directory
- Code: Select all
https://vovsoft.com/software/bulk-barcode-generator/
n7bii.VovSoft.Bulk.Barcode.Generator.1.1.rar.html
