HVAC Fan Problems after S1 to S2 MyIQ upgrade
Postby radarlaserau » Fri Mar 27, 2015 9:17 pm
Hey Guys
Just finished upgrading my series 1 to a MyIQ.
Problem is, I have lost Fan functions and control.
I can see the temperatures of the DZ HVAC resistor mod on the MyIQ and I have no errors on my OBDII
I have checked all known fuses and tested function of the fan with my S1 SZ HVAC.
Any clue where to start in diagnosing? has anyone had this fault before
radarlaserau
Postby jezzab » Sat Mar 28, 2015 11:05 pm
Sounds like it's a SZ HVAC and needs to be flashed to dual zone.
Postby radarlaserau » Sun Mar 29, 2015 12:02 am
jezzab wrote:Sounds like it's a SZ HVAC and needs to be flashed to dual zone.
Thanks for the tip mate
Is there anyway to tell a DZ from a SZ.
I removed the HVAC module with the MyIQ from the same Series 2, assumed it would be a DZ?? So I had it resistor modified when I had my IQ flashed.
Have purchased a second 'what i hope to be a DZ' HVAC and waiting on RS components to send me the resistors. So ill see if that makes any real difference.
Ps. No JayCar I could find around Adelaide stocks the 2.6K 5.6K resistors, They have everything but those two ohm values
radarlaserau
Postby radarlaserau » Sun Mar 29, 2015 11:26 am
Fixed :)
The original installer of the resistor's did a nice soldering job, but failed to protect the resistor legs from contacting a pad on the HVAC board, slipped plastic sheet between board and resistor, problem fixed.
radarlaserau
Postby jezzab » Sun Mar 29, 2015 4:08 pm
radarlaserau wrote:Fixed :)
Yup that would do it :)
Good stuff
  • In total there are 10 users online :: 0 registered, 0 hidden and 10 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 10 guests
