Ac won't turn on
Postby Notsus » Sun Oct 13, 2013 1:27 am
Hey guys I'm new to this hopefully someone can please help me
I got an 07 sv6 and my A/C just stop working I have checked the fuses they look fine so I'm guessing it's a relay would anybody know what relay I should be looking at ? Why I say it's a relay because my fan works all function works but when I press the A/C the light dose not turn on,
Thanks in advance
DOmm
Notsus
Postby silversv6 » Mon Oct 14, 2013 1:19 am
Relays & fuses: some in the passenger kick panel & are all listed on the cover, relay for AC compressor on mine (2010 SII) is in the fuse box under the bonnet. If the AC has low pressure (no gas) it won't turn on. If you have not used it for a long time the seals can shrink & you lose the gas. Should always run it for a bit weekly, even in winter. cheers
Postby Notsus » Sat Nov 30, 2013 11:45 pm
Hey mate sorry for the delay just got back from a long holiday still haven't fixed it yet how do u know if ur relay is blown ? I was doing a service on the car today the easy stuff oil change and I try to change the oil filter but couldn't get it off I had to take the airbox out to try to put a spanner and hit the end with a hammer but wouldn't budge and I notice that I got a pipe connected to my radiator is broken do u know what this is
Notsus
Postby Notsus » Sat Nov 30, 2013 11:51 pm
Notsus
Postby silversv6 » Sun Dec 01, 2013 12:30 am
Looks like you found your A/C problem. That broken pipe is going to the A/C condenser (in front of the radiator) You will need to replace the pipe & the "O" rings then take it to get re-gassed. Check that the condenser is not damaged as well. Most auto electricians are "air condition specialists" I don't know how that is, as it is a refrigeration mechanics trade! Cheers
Postby Notsus » Sun Dec 01, 2013 1:40 am
hey mate i appreciate your help, how can u tell if Ur a/c condenser is damage?
thank you
Notsus
Postby silversv6 » Sun Dec 01, 2013 8:14 am
Just do a general check for cracks around that pipe fitting on the condenser. When they re-gas it they can put a dye in it & if there is any leaks the dye will come out of the leak. Myself, I would pay the little extra & get the A/C person to replace all the seals. Cheers
Postby Belkina » Fri Dec 13, 2013 6:33 pm
Ive always loved this movie which in itself may turn some people off it, ha ha and enjoy all its twists and turns. But stupidly I forgot to program my recorder and I also forgot to program The Shadow on the Wall, dagnabbit
медицинские исследования по теме лечение рака почки, вопросы урологу[/url] - популярные материалы о доктор уролог на современная-урология.рф
Belkina
