12v power supply
Postby Yergin » Sat Mar 02, 2013 1:27 pm
Hi Guys,
Wondering if anyone knows how to remove and reinstall the 12v in the centre console, the plastic housing on mine broke and I have the new part but I cannot work out how to install it other than it needs to slot in from behind!..
Thanks a lot, hoping it's something easy that I can do! :-)
Yergin
Postby ZerOne » Sat Mar 02, 2013 4:09 pm
Hi there Yergin.
Yeah, this thing is a real PITA to get out, and you may need to remove the centre console assembly to get it out to replace.
(Here is a picture of the back of the power socket)
16057
As you can see from the above picture (Click on it for a large high res version), the black surround clips in to the center console assembly, and then the power socket is inserted in to the black ring....
You may be able to get good access to this section by removing the rear vents.
16024 16025
16027 16028
Once you have the vents removed, there are 2 screws holding the console in place.
16048
If you remove these screws, then you will be able to partially move the center console upward, to gain access to this section.
I hope this helps.
Postby Yergin » Mon Mar 04, 2013 10:16 pm
Thanks mate,
Those photos are awesome and will no doubt help when I do it, out of interest how do I go about getting the housing onto the power, is there a point that the power supply unplugs so I can insert it on.
If you don't know that's cool, i'll be doing this on Thursday or Friday when I have a couple of RDO's.
Thanks again, very much appreciated.
Nath
Yergin
Postby Yergin » Tue Mar 05, 2013 11:22 am
ok got the whole back section off today, can find the plug that clips into the power, but cannot get the centre console out or move the wires as it appears they clip in underneath!..
I knew there had to be a reason why the part was under $5 from Holden lol.
Yergin
Postby ZerOne » Tue Mar 05, 2013 1:11 pm
Ill post up as many pictures as possible, to try and help out.
Wires clipping underneath console.
16056 16055
16053 16052
If you want the whole center console bin out, its not too difficult to do, but it will take you around 15 to 30 minutes to complete.
1) Remove the Transmission trim. (To get access to the grab handle and handbrake cup trim bits)
16030 16031
2) Remove the small trim bit behind the cup holders.
16037
3) Remove the three screws for the cup holders.
16040
4) Remove the Cup holder (It just clips in after the three screws are removed)
16042
5) Remove the Handbrake cup trim. (I think its held in with two screws).
16032 16036
6) Remove the Upper grab handle trim. (Held in by two screws and clips in).
16034 16035
7) Remove the lower grab handle trim bit. (Held in by three screws)
16043 16044 16945
8) Next, remove the 1 screw inside the centre console bin. (You may need to remove the rubber mat to see it.
16028
9) Also don't forget to unscrew these 2 screws at the back of the centre console.
16049 16047
With all this stuff removed, the back of the centre console should be able to lift out,
how ever to get the whole assembly out, you will need to dis-engage the clips holding the assembly to the lower radio trim.
16051 16050 16046
I hope this helps.
Postby ZerOne » Tue Mar 05, 2013 1:18 pm
Also if you are going that far, you may want to look at fitting a centre console bin light.
You will need a dremel, and some steady hands (Which I didnt have on this day :(
You will also need a glove box switch and lamp.
16001 16234
16007 16002
Postby Yergin » Thu Mar 07, 2013 9:09 am
Thanks mate, don't need a console light (WM Caprice model, so already have it, thanks though)
If I can do this i'll save myself about $90 from getting my mechanic to do it!.
for a $2 part i'd rather not spend that kind of money!! :-)
Yergin
Postby Yergin » Thu Mar 07, 2013 12:54 pm
Completed in about 2 hours, so @ $88 p/h for labour I saved upto $180 by doing it myself!..
Thanks again ZerOne that helped a lot! :-)
Yergin
  • In total there are 7 users online :: 0 registered, 0 hidden and 7 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 7 guests
