Hey all,
I know I'm late to the game for mucking about with VE series 1 AV stuffs, but it's something I've wanted to do for quite a while now. Now the car I have has some interesting ways of getting stuff on the screen, it's about time to start. Any inputs,advice or warnings would be most appreciated! The car is a 07 Calais V International, so it has the rear seat dvd as well as factory Nav fitted. I'd very much like to retail all the current functionality where possible, of course!
Here's my list of planned things to do for the moment:
Source: RPi or Android miniPC running XBMC or similar
Connection: Looking at getting in via the Rear Aux port of the DVD player (see below)
Control: CANBUS shield on arduino Leonardo to simulate keyboard presses from steering wheel controls.
plus, get a VIM mod done so it will be visible while driving.
Here's my first test with the Pi:
The video worked quite nicely, but there was a lot of noise on the audio lines. I'm not sure if it is to do with the power, or with the TRRS cable I found for the test. I'm going to try running the Pi off a battery pack next and see if that helps - if the cable is crap that's not too bad, as the plan is to make a custom one to fit as nicely as possible. If I can't isolate the noise, and the aux jack is no longer a possibility, I'll look at splicing in a video switcher near the head unit, but I would very much like to have the option of both screens seeing the content from the PC, but we will see.
Here's the leonardo with it's transmogrifier (that's what they call it) to match the old arduino pin pattern.
Dry fit seems to work OK:
I'm planning on mapping the left scroll wheel signals to up, down and enter via the leonardo, but it does mean that I'm limited in what I can do with just three controls (a back button being the one I really need to make things easy). I'm thinking of making an XBMC skin that has on screen back controls, but there are things I need to overcome with that method as well. My first step though is to get the basics working though before I get too carried away.
A question for those in the know: while I'm happy to get stuck into coding with the OBD cable, once I want to mount this permanently in the car, can I do it via a tap of some sort into the GMLAN cables?
Anyway, that's where I'm at so far! I'll try and update this as I go with more details. I'm getting a 3d printer soon, so making some nice brackets to mount all this will be one of it's first jobs, I suspect.
