Ebay T-Harness S1 to S2 MyIQ Conversion Wiring
Postby radarlaserau » Tue Jan 27, 2015 2:56 am
Just a spreadsheet with harness colors for the Series 1 to Series 2 Stereo upgrade.
The Plug
http://www.ebay.com.au/itm/VE-COMMODORE ... 3f3e121bb5
Conversion Spread Sheet
https://drive.google.com/file/d/0B8lDrg ... sp=sharing
radarlaserau
Has thanked: 2 times
Postby TazzI » Thu Jan 29, 2015 7:12 pm
radarlaserau wrote:Just a spreadsheet with harness colors for the Series 1 to Series 2 Stereo upgrade.
The Plug
Absolute champion.
Thanks for sharing some really helpful links there! Greatly appreciated!
Postby radarlaserau » Wed Mar 18, 2015 10:23 am
Ok so I have run into a bit of trouble with my install, my MyIQ has been sitting in a box for quite sometime until today when i finally decided to test it out.
I have a Factory S1 Radio fitted in the car currently.
Replacing it with a MyIQ Level 1
Plugged in my conversion lead today and it instantly blew the 15A fuse in the boot???
Have I missed something, is something wrong with my spreadsheet?
Went over the cable before install with my multimeter and pinned out each pin and check for continuity.
Any help would be greatly appreciated
As Per this thread I have pin4 disconnected
view_doc.php?doc_id=67&model_id=19
radarlaserau
Postby TazzI » Thu Mar 19, 2015 6:41 pm
I think you might need to bring up the wiring diagrams for both the S1 and IQ, and match them up that way.
Well, I just tried to click on the spreadsheet which is no longer live, so cant help you much there if I cant see what you have done!
Postby silversv6 » Thu Mar 19, 2015 7:17 pm
TazzI wrote:I think you might need to bring up the wiring diagrams for both the S1 and IQ, and match them up that way.
Just sent you that spreadsheet. PDF. cheers
Postby radrace19 » Fri Mar 20, 2015 1:54 am
This is how I build my adapter harnesses and don't have a problem.
Function - S1 pin - S2 pin
Battery+ - 10 - 11
Ground - 12 - 12
Ground - 16 - 13
Battery+ - 15 - 15
GM LAN - 34 - 16
2009 G8 GXP
586 rwhp - LS3, Cam, TVS2300
radrace19
Postby radarlaserau » Sat Mar 21, 2015 1:23 am
So went back through the original wiring diagram, which I added the harness color too.
view_doc.php?doc_id=78&model_id=19
Seems the wiring diagram above has the instruction
X1 10 Battery Positive (+) >>>>>>>>>>>> Connect to X1-13 Ground
Is this the issue, as below looks correct
radrace19 wrote:This is how I build my adapter harnesses and don't have a problem.
Battery+ - 10 - 11
Ground - 12 - 12
Ground - 16 - 13
Battery+ - 15 - 15
GM LAN - 34 - 16
Thanks radrace19
radarlaserau
Postby silversv6 » Sat Mar 21, 2015 1:39 am
radarlaserau wrote:So went back through the original wiring diagram, which I added the harness color too.
Battery+ - 10 - 11
Ground - 12 - 12
Ground - 16 - 13
Battery+ - 15 - 15
GM LAN - 34 - 16
Thanks radrace19
Going by this I would assume: Pin 10 (series1) move to pin 11 (S2 IQ)...........Pin 16 (s1) move to pin 13 (IQ).........pin 34 (s1)move to pin 16 (IQ) & so on.....Cheers
Postby radarlaserau » Sat Mar 21, 2015 2:10 am
Then there is something seriously wrong with the Wiring diagram on
How Tos - Fitting a Series II IQ Unit for the Holden VE Commodore- By Matthew Jones (Matti Jones) (ZerOne)
radarlaserau
Postby TazzI » Sat Mar 21, 2015 11:26 am
radarlaserau wrote:Then there is something seriously wrong with the Wiring diagram on
Yeah, dont expect everything to be perfect first go! Probably something Matti just through together one night. Almost every single tutorial is made by Matti.
