Just a spreadsheet with harness colors for the Series 1 to Series 2 Stereo upgrade.
The Plug
http://www.ebay.com.au/itm/VE-COMMODORE ... 3f3e121bb5
Conversion Spread Sheet
https://drive.google.com/file/d/0B8lDrg ... sp=sharing
radarlaserau wrote:Just a spreadsheet with harness colors for the Series 1 to Series 2 Stereo upgrade.
The Plug
TazzI wrote:I think you might need to bring up the wiring diagrams for both the S1 and IQ, and match them up that way.
Well, I just tried to click on the spreadsheet which is no longer live, so cant help you much there if I cant see what you have done!
radrace19 wrote:This is how I build my adapter harnesses and don't have a problem.
Function - S1 pin - S2 pin
Battery+ - 10 - 11
Ground - 12 - 12
Ground - 16 - 13
Battery+ - 15 - 15
GM LAN - 34 - 16
radarlaserau wrote:So went back through the original wiring diagram, which I added the harness color too.
view_doc.php?doc_id=78&model_id=19
Seems the wiring diagram above has the instruction
X1 10 Battery Positive (+) >>>>>>>>>>>> Connect to X1-13 Ground
Is this the issue, as below looks correctradrace19 wrote:This is how I build my adapter harnesses and don't have a problem.
Battery+ - 10 - 11
Ground - 12 - 12
Ground - 16 - 13
Battery+ - 15 - 15
GM LAN - 34 - 16
Thanks radrace19
radarlaserau wrote:Then there is something seriously wrong with the Wiring diagram on
How Tos - Fitting a Series II IQ Unit for the Holden VE Commodore- By Matthew Jones (Matti Jones) (ZerOne)
