FG Falcon Instrument Cluster EEPROM Programming
Postby TazzI » Sat May 16, 2015 6:55 pm
Been a tad slow/quiet on the Ford front recently.
I didnt have the tools equipped to attack the FG and anything newer on the Fords before.. although I think I can safely says Im about there now.
Im now equipped with:
-An army of ELMs
-Modified SWC ELMS
-VCM2
-MX WIFI
-TCB
-AVT
and a few other tools :lol:
I have been having trouble getting connected up to the FG cluster.. since I didnt find any information.. at all.. about the FG's. Turns out you need custom tools, software and a bit of luck to get connected up to them successfully!
Between this army of tools, Ill be setting up a virtual car on a programming bench so I can emulate the ECU response, cluster, radio ect to attack IDS and FMP.
Ontop of this, Ill be emulating the ECU speed data (Hopefully) to control the Cluster.. and read off the odo reading at each 1km interval. Anyone thats keen to join in, you'll need to get an FG cluster and be prepared to break something ;)
Postby aumatt » Sat May 16, 2015 8:06 pm
I've got several fg clusters , let me know what you need
Postby TazzI » Sat May 16, 2015 11:32 pm
aumatt wrote:I've got several fg clusters , let me know what you need
Will probably need to send you a modified cable to start playing around ;)
Postby LangasLS » Thu Jul 02, 2015 2:24 am
Well, I had nothing better to do this evening so I crunched some numbers.... These are modifications to the 99128km dump Tazzi posted up earlier in the thread.
If someone with a cluster could test these two bins and let me know what they come up with that would be awesome.
:D
Postby TazzI » Thu Jul 02, 2015 12:48 pm
LangasLS wrote:Well, I had nothing better to do this evening so I crunched some numbers.... These are modifications to the 99128km dump Tazzi posted up earlier in the thread.
:D
Will give it a go this arvo if I find time!
Postby TazzI » Mon Jul 13, 2015 3:28 pm
Alllllright so the FG clusters actually have both HS can and MS can inputs in the pinout! :D
Riiiiiight, that makes more sense. Now to work out which one gets which info or which is used for programming. Assume MS can will be programming, and HS can will be all the general info including speed/rpm 8-)
Next on the agenda, a HS and MS CAN enabled ELM ;)
Postby aumatt » Mon Jul 13, 2015 5:33 pm
MS Can is used for Diagnostics. I couldnt set my chinese ELM to talk so ended up buying a STN110 from Scantool, works a treat. Can extract some info via mode 21.
Postby TazzI » Mon Jul 13, 2015 8:20 pm
aumatt wrote:MS Can is used for Diagnostics. I couldnt set my chinese ELM to talk so ended up buying a STN110 from Scantool, works a treat. Can extract some info via mode 21.
Yeah the mx I picked up will work too, but wifi is painful to deal with. But iv wired up an elm today to try it out. It's all about entering the elm into the correct custom settings suitable for the ms can speed.
Actually got a bit adventurous and added a switch for ms and hs CAN.
Pm sent.
Postby TazzI » Fri Aug 21, 2015 11:50 am
Its gotten to the point, Iv been looking at actually buying a FG falcon to work on :shock:
Need logs of the car running and rolling about to progress further.. and.. without it.. its not gonna happen.
If anyone owns a FG.. nows the time to chirp up! :lol:
Postby LangasLS » Fri Aug 21, 2015 2:15 pm
I can borrow one for a night :)
  • In total there are 26 users online :: 0 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 26 guests
