Power WIndow Dignostics for VE Commodores
Postby ZerOne » Thu Jun 16, 2011 8:39 am
The following forum thread is for discussing the Accessing the Power Window Diagnostics for VE and VEII Commodores document, located in our Documents section.
Postby robpagnoni » Sat Mar 09, 2013 4:53 pm
For those that know......How do I remove the power window switch gear from the centre console trim? (without cracking the trim) The trim has already been removed from the vehicle.
cheers...
robpagnoni
Postby ZerOne » Sat Mar 09, 2013 5:03 pm
The power window switch just clips in to the gear shift surround.
Carefully dis-engage the clips around the power window switch (using a small flat headed screwdriver), and push the switch assembly outwards from the trim surround.
(The actual hard part is removing the transmission trim, so if you have gotten that far, then the rest is much easier).
Hope this helps.
Postby robpagnoni » Sat Mar 09, 2013 5:10 pm
Perfect....thanks!
robpagnoni
  • In total there are 9 users online :: 0 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 9 guests
