Fitting an aftermarket exhaust to VE Models
Postby ZerOne » Tue Jan 10, 2012 4:44 pm
The following forum thread is for discussing the Fitting an after market exhaust document, located in our Documents section.
Postby gruntly69 » Fri Mar 16, 2012 11:45 am
Howdy,
I thought fitting an aftermarket system to the alloytec's required a change in the PCM calibration to with oxy sensors not working correctly?
Cheers Grant
gruntly69
Postby msenj » Sat Mar 17, 2012 11:00 pm
gruntly69 wrote:Howdy,
Cheers Grant
I can't see why, and I haven't had any issues with mine... Provided all 4 sensors are in place, there shouldn't be any issues.
(The exhaust on my LE0 Alloytec is from an E1 series Clubsport though, so it's not entirely aftermarket.)
msenj
Postby ZerOne » Sun Mar 18, 2012 8:50 am
The Xforce 3" fitted in the above doco was fitted to a V8 model.
I originally had one of the post HEGOs running lean, but that was because I was a bit of a dodgy bastard, and had an air leak between the Cat, and the exhuast.
Once I fixed the leak, everything was fine.
Over the radiator cold air intakes (Or any intake that moves the MAF position closer to the throttle body) will trip the check Engine light though. (For both V6 and V8 models).
  • In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 14 guests
