Postby msenj » Thu Mar 01, 2012 4:02 pm
I'm glad someone wants to keep going with this because I'm just about to give up.
All I've been doing in my spare time, which I have a lot of now that I'm unemployed, is sit here, changing addresses, writing to the EEPROM and rebooting the headunit. I'm up to about 20 hours of this and I have gotten exactly nowhere.
msenj
Postby MartinM » Thu Mar 01, 2012 4:15 pm
we so need an on the fly programmable eeprom emulator to do this...........going to search now :)
MartinM
Postby msenj » Thu Mar 01, 2012 4:33 pm
My "development environment"
msenj
Postby MartinM » Thu Mar 01, 2012 4:39 pm
found this one so far
http://esdn.com.au/Products/EEPROM_Emulator.html
That only takes care of 93C series (46 and 56) chips, there must be one out there for 24C series
With these we can watch teh changes in real time and work out what control is changing what byte
MartinM
Postby jezzab » Thu Mar 01, 2012 6:11 pm
Tried reading the EEPROM with the unit running?
Postby msenj » Thu Mar 01, 2012 8:21 pm
jezzab wrote:Tried reading the EEPROM with the unit running?
Yup. That's how I got all the option setting addresses in the Excel spreadsheet map I posted.
I can't do it in the car while it's moving though (I.e for the VIM address/es)
msenj
Postby Rayrayrr » Fri Mar 02, 2012 8:07 am
Hey guys just a little update.
I reprogrammed the calais headunit that i bought from ebay and installed it and also soldered the resistors onto the HCM.
All went well. except one thing i did notice.. my auto headlights switch makes the lights stay on even when its light outside... took roughly 15mins to turn off in the morning..
also one more question, will a gscan tool be able to turn my SIC into sports mode?? or will i have to get my hands on a tech2?
ive also herd that the oil pressure appears as nothing on the SIC is this true?
Thanks in advance!!
Rayrayrr
Has thanked: 3 times
Postby MartinM » Fri Mar 02, 2012 11:03 am
Rayrayrr wrote:Hey guys just a little update.
Thanks in advance!!
Good work, sounds like you may have an issue with the light sensor in the centre of the dash causing the auto headlamp issue. Do check that you put the resistors across the correct pins, just in case you accidently put one across the dash light sensor wires
Not sure whether a gscan tool has the ability to swap the SIC into sports mode, a tech 2 definitely can and I am working on a "hack" for this at the moment using a Pontiac SIC
There are two sorts of SIC module, one has the older twin Atari style guages and the later ones have 3 gauges (much nicer) The Oil Temperature setting does not get passed to the SIC by default but this can be changed, again by a tech 2 to give a fully functional gauge setup (again this is on my to do list for a hack)
MartinM
Postby msenj » Fri Mar 02, 2012 11:06 am
I have started modifying the sensors, in anticipation of doing the conversion this afternoon...
From left to right - 4 Pin sunload sensor, cabin air sensor, ambient temperature sensor.
Because I don't have any of the factory connectors, I'll be adding my own connectors at the sensor and HCM ends, so the sensors still remain plug and play :)
msenj
Postby MartinM » Fri Mar 02, 2012 11:38 am
msenj wrote:I have started modifying the sensors, in anticipation of doing the conversion this afternoon...
Thanks, that answers my eralier query on whether the loom was ready for the sensors.......apparently not, what a shame, this also strengthens the rationelle behind the resistor mod as the sensor fit isnt just a straightforward $100 plus plug n play install
MartinM
  • In total there are 12 users online :: 0 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 12 guests
