Postby advancedservers » Sun Nov 10, 2013 5:55 pm
I'm using an arduino to talk to my iphone and the can bus shield to display the track info and still be able to use the steering controls... The arduino talking to the iphone was easy just waiting on the can shield to arrive to test the next bit.
Flashing the vim stuff over obd is way over my head... While I'm waiting for the can bus I'm trying to find the vim location in the EEPROM to flash with my programmer.
Also just wanted to say what awesome work you and the guys have done here.
Thanks !!!
Ben
advancedservers
Has thanked: 2 times
Postby jezzab » Mon Nov 11, 2013 7:18 am
advancedservers wrote:I'm using an arduino to talk to my iphone and the can bus shield to display the track info and still be able to use the steering controls... The arduino talking to the iphone was easy just waiting on the can shield to arrive to test the next bit.
Thanks !!!
Ben
Ahh k. Well 29bit is what you want to look at and check out the "GMLAN Bible". You will get more info for what you are doing from that then anything else. GMW3110-2010 is all 11bit and not what your looking for
Postby advancedservers » Mon Nov 11, 2013 7:52 am
Ok Jezzab. Thanks
advancedservers
Postby advancedservers » Wed Nov 13, 2013 12:10 pm
Jezzab are you located in Mackay?
advancedservers
Postby jezzab » Wed Nov 13, 2013 3:12 pm
advancedservers wrote:Jezzab are you located in Mackay?
I am mate
Postby advancedservers » Wed Nov 13, 2013 3:39 pm
I work for Epoca... I'm in the Brisbane office but I travel to Mackay all the time.. I will have to pop in and say hi.. I should be up there in a couple of weeks
advancedservers
Postby advancedservers » Wed Nov 13, 2013 3:53 pm
If you so t mind that is .
advancedservers
Postby advancedservers » Wed Nov 13, 2013 9:23 pm
If you are having problems flashing the HVAC Module instead of removing the chip just lift pin 8 (VCC) from the board.
Mine flashes perfect.
advancedservers
Postby advancedservers » Fri Nov 15, 2013 10:47 am
Ok this weekend I am going to start looking for the elusive VIM location.
I have desoldered the eeprom from the main board and added some wires and socket so I can change the eeprom
over quickly while I test.
I am going to use the following assumptions from what I have read here an some guesses.
1. VIM is stored as 2 bytes
2. The stored value is related to the speed that the cars turns the screen off( mine is 3 kph)
3. This value is stored as plain text ?? maybe as hex?? decimal ??
4. To disable VIM change the stored value from 3 kph to 200 kph
5. Its in the second half of the eeprom ( Thanks Jezzab)
6. the reverse enable is probably stored close by.
I'll let you know how I go.
Ben
advancedservers
Postby TazzI » Fri Nov 15, 2013 9:39 pm
advancedservers wrote:Ok this weekend I am going to start looking for the elusive VIM location.
Ben
Good collection of info right there.
  • In total there are 10 users online :: 0 registered, 0 hidden and 10 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 10 guests
