To gain access to the Invite Only forum you must be invited by a member of that forum. That member will PM the mods or admins (NOT you) saying that they nominate you for access. THEY will be responsible for your actions. If you don't post and just leech info, you will BOTH be removed. Dont send a PM to the moderators or admins asking for access, you really dont want to see the result. If you submit information, you may simply be invited
by 69terra69 » Sun Jun 02, 2013 1:17 pm
thanks for reply mate. i pulled it apart checked all the connections then put it together again then in the car and still no sound
69terra69
- Starting Ignition
- Has thanked: 0 time
- Been thanked: 0 time
by msze1988 » Tue Jun 04, 2013 9:18 pm
is that problem happened even if played the radio ,Aux and CD ?
msze1988
- Starting Ignition
by 69terra69 » Tue Jun 04, 2013 11:25 pm
yes same thing on either aux cd radio wont play anything but will still play the beep tones fine.
69terra69
- Starting Ignition
by zeep » Wed Jun 12, 2013 8:45 pm
Hi Guys,
Just ordered a second stereo for my Caprice on eBay and am keen to pull it apart and play with it. I was trying to download some of the attachments in this thread to have a look in advance but the zip files always seem to be corrupted. Has anyone else had this problem?
Thanks, Daniel
zeep
- Newbie Modder
by TazzI » Wed Jun 12, 2013 9:59 pm
zeep wrote:Hi Guys,
Thanks, Daniel
Most attachments will be corrupt/lost due to the site moved over to a new server/host. Should be able to do most changes if read through whats been done/ what was needed to be changed and the various hints for other things
- Moderator
- Images:
2
- Has thanked: 16 times
- Been thanked: 41 times
by zeep » Thu Jun 13, 2013 8:01 pm
No worries thought it might have been because I only just joined the forum and didn't have permission.
zeep
- Newbie Modder
by mitchelldrysdale » Wed Jul 17, 2013 6:50 pm
Hi all,
Long time reader first time post. I recently bought a e2 clubsport headunit complete with matching hvac module (score
) off ebay and i have taken an eeprom dump. I thought some of you guys might be interested because it does actually come up with the E2 start up screen. If anyone would like a look, im happy to put it up
mitchelldrysdale
- Kicking Tyres
by advancedservers » Thu Oct 31, 2013 3:12 pm
Firstly I just want to thank all the members for their hard work and determination in successfully pulling off the radio change over.
I have read and printed then read again all of the information on this site. I have a huge folder with all the printed info(should post a picture of it) Just tons of information...
Anyway I have looked but been unable to find the DZ eeprom to flash. (except one corrupt zip file)
Could anyone please post a copy.
If I can help in any way just let me know.. As I said I have complied quite a large amount of information in hardcopy and PDF, so if anyone would like a copy just let me know. I also have found an Australian supplier for the 3m Clips and GQ-4x programmer if anyone is interested...
Thanks
Ben
advancedservers
- Starting Ignition
- Has thanked: 2 times
by advancedservers » Fri Nov 01, 2013 8:27 pm
Here is my '10 SSV Radio Eemprom Dump Original and unmodified, dumped with MCUMall GQ-4x.
advancedservers
- Starting Ignition
by advancedservers » Sun Nov 03, 2013 4:15 pm
This is the dump from the original no LCD head unit.
advancedservers
- Starting Ignition
