Postby msze1988 » Thu Apr 25, 2013 5:47 pm
I know it is posted but i cant fine the hex location : 034C is on my unit
msze1988
Postby jezzab » Thu Apr 25, 2013 6:28 pm
What year is your unit? Have you worked out if its an early or late unit? If your VIN starts at location 0x80 its a late unit. If it starts at 0xF0 its an early unit
Find the location of that and we can work out if its early or late and then tell you where the startup logo byte is ;)
Postby msze1988 » Wed May 08, 2013 6:24 am
hi guys
here is my head unit data and it seams to be its from the newer models so if some body can tell me where is that codes for the logo (is it the highlighted one ? coz i tried to change it from 02 to 04 but nothing happened) and for the Facia Pairing Data
thanks
msze1988
Postby 69terra69 » Tue May 14, 2013 4:58 pm
hey guys not sure where im suppose to ask questions but i thought here will do.
ive just been down to my local jaycar and got some resisters but the closest ones they had to whats needed are, 2.4k, 2.7k and 5.6k.
so im asking will these still work and if so will it change anything ? also should i use the 2.4k or the 2.7k
any help would be great thanks.
69terra69
Postby doubledip » Tue May 14, 2013 5:35 pm
shouldn't be asking.. should be looking/reading.. all the info is in the tech document area on carrying out this mod... it shows/explains the differences between the different value resistors
Postby 69terra69 » Tue May 14, 2013 10:18 pm
thanks mate found it just getting used to navigating on this forum.
69terra69
Postby doubledip » Tue May 14, 2013 11:15 pm
No worries have no problems with newbies but most that come on here are leeched wanting information but no intent to give.
Postby 69terra69 » Sat Jun 01, 2013 5:56 pm
hey guys im having trouble with putting my changed vin info back on the deck it writes half way and stop and says error check connection on board. ive literally been sitting here all day fiddling with the connection and it makes no difference stops at 37%.
any help or getting pointed in the right direction would be much appreciated.
also want to check if these settings are right ?
69terra69
Postby 69terra69 » Sat Jun 01, 2013 8:01 pm
well i finally got it to work its all in the car working
but now i got no sound ? the beeps work but no sound on aux, radio, cd ect but if i press mute with the volume under 36 and unmute it you can hear the music very slightly but as soon as you touch anything it will stop.
any ideas ??
69terra69
Postby msze1988 » Sun Jun 02, 2013 6:20 am
69terra69 wrote:well i finally got it to work its all in the car working
any ideas ??
Try to check the white cable which connect the CD player to the mother board of the unit coz some times when it has a slight lose it can cause such a problems with the sound
msze1988
  • In total there are 9 users online :: 0 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 9 guests
