Postby JJ212 » Wed Sep 09, 2015 11:33 pm
Has anyone figured out the difference in bins for the speedo gauge compression in ssvs?
JJ212
Postby Pavi » Wed Sep 07, 2016 12:51 pm
Hi everyone
I m trying to put series 2 cluster in series 1 bcoz when I bought this car it has iq with navigation fitted and my old cluster shows the errors , I change vin and put it into the car but it shows abs and traction fault , can anyone help me out with this problem
Thanx for any kind of help
Pavi
Postby Pavi » Wed Sep 07, 2016 12:54 pm
this is the 24c16 bin file from cluster
this clustr has been taken out from series sv6 ute manual
and my sv6 is manual too
Pavi
Postby jezzab » Wed Sep 07, 2016 2:17 pm
The config in the cluster wont match your car for a start (its setup for a 3.6L SIDI LFX engine). Thats why you get the ABS/ESP faults. The other thing is that Nav hasnt been enabled on the cluster your attempting to put in so its not going to fix these "errors" you say your original did. Nav wont even show at all.
How are you going to match the KM of your car??
Postby Pavi » Wed Sep 07, 2016 6:09 pm
Thanx jezzab for reply
EEPROM is completely different than my old cluster , I m trying to work that out ,
So this series 2 cluster can't fit in my series 1
Pavi
Postby jezzab » Wed Sep 07, 2016 6:56 pm
Pavi wrote:Thanx jezzab for reply
It has to be reprogrammed (config and KM). Not just a VIN change
Postby Pavi » Wed Sep 07, 2016 11:15 pm
Ok , so I have to find the locations of kms and engine configuration . Ok is there any hint for that. EEPROM looks very difficult to understand bcoz 1st 3 lines has bytes r little bit tricky but i m on to it
Pavi
Postby Pavi » Thu Sep 08, 2016 9:35 am
A little bit more about that the cluster from series 2 it has 028048 kms on it and the hex value should be 7F BF FF FD as but in this case eeprom does not have anything like that I can tell there is no 30 location like the white back clusters has . Looks more difficult but fingers cross
Pavi
Postby TazzI » Thu Sep 08, 2016 11:08 am
Pavi wrote:A little bit more about that the cluster from series 2 it has 028048 kms on it and the hex value should be 7F BF FF FD as but in this case eeprom does not have anything like that I can tell there is no 30 location like the white back clusters has . Looks more difficult but fingers cross
Series1 and Series2 are different.
In all honesty, simply looking at the bin is not going to get you very far. Nothing is explained in the bin, so any one of the bytes could literally mean anything.
Postby Pavi » Thu Sep 08, 2016 11:27 am
Thanx tazzl
So I need a tech 2 for that and permission from tis to do that
To find Kms I think if I put the cluster in and drive the car for 200-300kms then take the eeprom reading and compare then may be a chance I can find the locations for that.
Thank u very much for correcting me
Pavi
