GM ALDL Logging and Scanning
Postby TazzI » Fri Jun 07, 2013 2:53 pm
Yeah not "100%" wiped, but it set is back to factory settings. Meaning, fresh off the production line. Doesnt reset the odo though. Nothing wipes that unless manually changing it or over aldl with the right knowledge. ;)
Been doing some logging of the SRS module and BCM modules fault codes.
SRS faults found:
161 HISTORY: CONFIGURATION MISMATCH TO INSTRUMENT
163 HISTORY: SDM Internal Fault
133 HISTORY: LEFT PERIPHERAL ACCELERATION SENSOR IDENTIFICATION FAULT
134 HISTORY: RIGHT PERIPHERAL ACCELERATION SENSOR IDENTIFICATION FAULT
135 HISTORY: LEFT PERIPHERAL ACCELERATION SENSOR HARDWARE FAULT
136 HISTORY: RIGHT PERIPHERAL ACCELERATION SENSOR HARDWARE FAULT
129 HISTORY: LEFT PERIPHERAL ACCELERATION SENSOR LINE FAULT
130 HISTORY: RIGHT PERIPHERAL ACCELERATION SENSOR LINE FAULT
131 HISTORY: LEFT PERIPHERAL ACCELERATION SENSOR COMMUNICATION FAULT
132 HISTORY: RIGHT PERIPHERAL ACCELERATION  SENSOR COMMUNICATION FAULT
97 HISTORY: RIGHT HAND SIDE AIRBAG CIRCUIT SHORT TO BATTERY
98 HISTORY: RIGHT HAND SIDE AIRBAG CIRCUIT SHORT TO GROUND
99 HISTORY: RIGHT HAND SIDE AIRBAG CIRCUIT CAPACITANCE TOO HIGH
100 HISTORY: RIGHT HAND SIDE AIRBAG CIRCUIT CAPACITANCE TOO LOW
101 HISTORY: RIGHT HAND SIDE AIRBAG CIRCUIT RESISTANCE TOO HIGH
102 HISTORY: RIGHT HAND SIDE AIRBAG CIRCUIT RESISTANCE TOO LOW
247 HISTORY: RIGHT SIDE AIRBAG CIRCUIT POWER STAGE ERROR
81 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT SHORT TO BATTERY
82 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT SHORT TO GROUND
83 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT CAPACITANCE TOO HIGH
84 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT CAPACITANCE TOO LOW
85 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT RESISTANCE TOO HIGH
86 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT RESISTANCE TOO LOW
247 HISTORY: LEFT HAND SIDE AIRBAG CIRCUIT POWER STAGE ERROR
65 HISTORY: RIGHT HAND PRETENSIONER CIRCUIT SHORT TO BATTERY
66 HISTORY: RIGHT HAND PRETENSIONER CIRCUIT SHORT TO GROUND
67 HISTORY: RIGHT HAND PRETENSIONER CIRCUIT CAPACITANCE TOO HIGH
68 HISTORY: RIGHT HAND PRETENSIONER CIRCUIT CAPACITANCE TOO LOW
69 HISTORY: RIGHT HAND PRETENSIONER CIRCUIT RESISTANCE TOO HIGH
70 HISTORY: RIGHT HAND PRETENSIONER CIRCUIT RESISTANCE TOO LOW
247 HISTORY: RIGHT HAND BELT PRETENSIONER CIRCUIT POWER STAGE ERROR
49 HISTORY: LEFT HAND PRETENSIONER CIRCUIT SHORT TO BATTERY
50 HISTORY: LEFT HAND PRETENSIONER CIRCUIT SHORT TO GROUND
51 HISTORY: LEFT HAND PRETENSIONER CIRCUIT CAPACITANCE TOO HIGH
52 HISTORY: LEFT HAND PRETENSIONER CIRCUIT CAPACITANCE TOO LOW
53 HISTORY: LEFT HAND PRETENSIONER CIRCUIT RESISTANCE TOO HIGH
54 HISTORY: LEFT HAND PRETENSIONER CIRCUIT RESISTANCE TOO LOW
247 HISTORY: LEFT HAND BELT PRETENSIONER CIRCUIT POWER STAGE ERROR
33 HISTORY: PASSENGER AIRBAG CIRCUIT SHORT TO BATTERY
34 HISTORY: PASSENGER AIRBAG CIRCUIT SHORT TO GROUND
35 HISTORY: PASSENGER AIRBAG CIRCUIT CAPACITANCE TOO HIGH
36 HISTORY: PASSENGER AIRBAG CIRCUIT CAPACITANCE TOO LOW
37 HISTORY: PASSENGER AIRBAG CIRCUIT RESISTANCE TOO HIGH
38 HISTORY: PASSENGER AIRBAG CIRCUIT RESISTANCE TOO LOW
247 HISTORY: PASSENGER AIRBAG CIRCUIT POWER STAGE ERROR
17 HISTORY: DRIVER AIRBAG CIRCUIT SHORT TO BATTERY
18 HISTORY: DRIVER AIRBAG CIRCUIT SHORT TO GROUND
19 HISTORY: DRIVER AIRBAG CIRCUIT CAPACITANCE TOO HIGH
20 HISTORY: DRIVER AIRBAG CIRCUIT CAPACITANCE TOO LOW
21 HISTORY: DRIVER AIRBAG CIRCUIT RESISTANCE TOO HIGH
22 HISTORY: DRIVER AIRBAG CIRCUIT RESISTANCE TOO LOW
247 HISTORY: DRIVER AIRBAG CIRCUIT POWER STAGE ERROR
BCM faults found:
DTC#1 HISTORY: OutPut OverLoad
DTC#28 HISTORY : Antenna Drive Circuit Overload
DTC#18 HISTORY : Auxiliary Serial Data Bus Fault
DTC#17 Current: Not Okay to Start, Received from PCM
DTC#24 Current:Key Rolling Code Error
DTC#25 Current:Engine Start without Slip ring Communication
DTC#7 Current: PCM Data Lost
DTC#26 Current: ABS Data Lost
DTC#27 Current: Instrument Data Lost
DTC#22 Current: Battery Voltage too High
DTC#21 Current: Battery Voltage Too Low
DTC#23 Current: Door Lock/Unlock circuit Overload
DTC#5 Current: Rear Lamp Bulb Fail
DTC#6 Current: Rear Break Bulb Fail
DTC#29 Current: Stoplamp or Parklamp Fuse Failure
DTC#1 Current: Output Overload
DTC#28 Current: Antenna Drive Circuit Overload
DTC#18 Current: Auxiliary Serial Data Bus Fault
DTC#19 Current:  EEPROM Error
DTC#20 Current:  RAM Error
The BCM fault codes were a bit weird, since they also had "times occurred" and "ignition cycles" which was hard to work out what went with what?
And also thought there would be more fault codes in the bcm, but looks like it more revolves around whether it is receiving data from the modules.
Also found Alarm codes:
Bonnet Alarm   Triggered
Rear Compartment Alarm   Triggered
Passenger’s Door Alarm      Triggered
Driver’s Door Alarm   Triggered
Ignition Alarm      Triggered
Bonnet Alarm   History
Rear Compartment Alarm   History
Passenger’s Door Alarm      History
Driver’s Door Alarm   History
Ignition Alarm      History
I actually had each of these triggered in my car, so either its had a rough history or dodgy connections.
Postby shifte » Sun Jun 09, 2013 10:01 pm
As for the calculating the security/cluster unlocking code, I have almost got it sussed. So the 1st Byte response works out to be the inverse of the 2nd Byte recieved plus BD hex ( 189 Decimal) and the 2nd Byte Response is the inverse of the 1st Byte received plus 86 hex (134 Decimal).
i.e. Recieved 92, 97
I have also got the AAPL decompiled source code in VB6 however to open in VB2012 I need VB2008 to convert it which I don't have handy at the moment so the files are of little use yet.
shifte
Postby TazzI » Mon Jun 10, 2013 12:07 am
shifte wrote:As for the calculating the security/cluster unlocking code, I have almost got it sussed. So the 1st Byte response works out to be the inverse of the 2nd Byte recieved plus BD hex ( 189 Decimal) and the 2nd Byte Response is the inverse of the 1st Byte received plus 86 hex (134 Decimal).
Already been down that path..
Source code will not run no matter what you open it in. Its old software, Using old vb. Most vb decompiled "source" code simply provides an idea of how the program runs.. its not an actual copy, and doesnt work either :?
Postby shifte » Tue Jun 11, 2013 12:20 am
Hi All, So I've figured out the slight error in calculating the security code mentioned above. The formula is (BE86-(Byte 2 & Byte1)). For example 9792 = 38802Dec & BE86 = 48774Dec therefore 48774-38802=9972 which equals 26F4 in hex. So to put this into picture:
Sending frame F2571100A6 and getting a response of F2581192977C you would then do the above maths and send
F259110126F489 (updating the checksum accordingly). The cluster would then send F2581126F48B confirming the unlock was successful.
Next challenge = Retrieving the bin over aldl... I've heard we need to use mode 22 for read access but haven't tried it yet.
ShiftE
shifte
Postby TazzI » Wed Jun 12, 2013 12:43 pm
Been doing a bit of work on the abs module lately when the tech2 has decided it wants to work again.
Gave a go at logging the ABS bleed procedure.
It requests a few tables and status before hand:
First requests from the tech2 are: F9,57,01,00,AF
And F9,57,01,04,AB
And also: 92,55,19
Which gave a response back of: 93,5E,08,02,FF,04,02,02,02,02,00,chksum
When entering the abs bleed procedure, it runs the through a series of steps an requirements that must be completed prior to performing the bleed (usual bleed stuff).
After doing that and clicking continue once ready, it fires off whole heap of info:
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 20 40 28 A4 E0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 00 00 E1 50 00 02 DF 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 10 00 00 12 00 00 30 00 10 00 00 00 00 00 E2 A8
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 01 00 A0 20 E0 F0 A3 01 A2 20 1C A3 01 AC 20 1E 22 20 08 05 58 00 11 89 FA 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 01 20 00 00 00 00 08 16 00 00 40 20 0C 00 00 10 00
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 03 20 80 08 F0 E0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 08 02 79 A1 03 12 FA F7 44 06 49 E9 5D 1F 21 21 24 59 24 49 4D 92 52 AE 50 52 10 20 81 00 00 18 20 00 02 04 10 00 00 00 00
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 20 40 28 A0 D0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 00 40 2A F0 20 40 BC 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 11 00 08 00 10 00 A0 04 22 20 00 00 E8 00 00 10
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 07 20 80 28 C4 F0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 00 80 E1 40 00 02 DF 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 10 00 00 12 00 00 00 70 18 00 10 00 00 00 00 00
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 00 40 40 A8 C0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 00 40 2A F0 20 40 BC 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 11 00 14 01 00 00 20 88 00 C1 11 01 02 80 04 04
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 40 40 40 50 C0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 00 00 CA B8 04 22 DF 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 80 00 00 12 20 00 80 04 00 00 00 00 00 00 00 E2
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 00 40 40 A8 C0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 00 41 94 78 00 40 BE 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 B1 00 41 01 00 00 20 00 00 60 A0 00 00 00 04 08
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 07 20 A0 00 C8 F0 A3 01 A2 20 1C A3 01 AC 20 1E A2 01 00 00 F2 30 20 44 DF 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 01 00 00 00 00 00 48 89 00 30 20 40 00 00 04 08 08
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 40 20 28 68 F0 A3 01 A2 20 1C A3 01 AC 20 1E A2 01 00 00 CC 60 48 88 7D 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 40 00 10 00 00 00 28 44 00 00 40 38 2C 00 00 00
F9 D8 06 04 00 01 00 00 12 06 00 6B 01 A6 20 78 D1 01 F0 05 7A D6 21 95 02 36 A3 01 9C 20 2A A2 2B 7C A2 2B 7E A2 2B 7A 09 01 7A B1 04 28 B2 2B 20 28 1E E0 28 F8 07 40 A0 7C 78 04 7E 7C B1 30 20 AD 14 28 28 0B 99 08 29 DF 05 17 00 80 00 20 F0 A3 01 A2 20 1C A3 01 AC 20 1E A2 1D 40 00 E4 50 00 04 DF 1F 94 20 22 D7 F1 08 0A 22 64 1E 22 A2 22 22 71 07 25 21 02 08 10 00 20 00 12 40 40 00 08 07 09 00 20
After several retries with multiple loggers, I still get the same rubbish, although its slightly different.
I suspect its actually ment to be a mode 4 (manual control), which would be increment a single byte to manual configure the values and such.
But to why im not able to log this...Im guessing its something to do with the bench setup.. somethings off somewhere.
I noticed when first entering the abs/tc section when it brings up the modules information, it sends off a few of the "rubbish" lines, so will plug it into the car and log what it is actually sending.
Also saw it fire off a F9,59,04,00,FF,01,chksum. Thats sent also when looking at the general information of the module.
Postby TazzI » Wed Jul 17, 2013 12:16 pm
Some more fiddling with the PCM/Engine side of things with the tech2. I thought the tech2 would have had some "program" features for the pcm such as changing the VIN, although didnt find anything!.
Im sure I saw that somewhere in the tool.. could be wrong.
But I grabbed a whole heap of mode4 frames which allow manual control of various parameter eg RPM, EGR ect.
-IAC System
       -RPM Control
  “Clicking increase!”
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 5E 00 00 00 00 00 00 00 00 78
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 62 00 00 00 00 00 00 00 00 74
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 64 00 00 00 00 00 00 00 00 72
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 66 00 00 00 00 00 00 00 00 70
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 68 00 00 00 00 00 00 00 00 6E
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 6A 00 00 00 00 00 00 00 00 6C
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C3 70 00 00 00 00 00 00 00 00 66
When Exiting: From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D9
       -IAC Control
Clicking increase
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 64 00 00 00 00 00 00 00 00 74
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 7D 00 00 00 00 00 00 00 00 5B
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 96 00 00 00 00 00 00 00 00 42
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 AF 00 00 00 00 00 00 00 00 29
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 C8 00 00 00 00 00 00 00 00 10
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 E1 00 00 00 00 00 00 00 00 F7
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C1 FA 00 00 00 00 00 00 00 00 DE
       -IAC Reset
Click reset
From Tech2: F7 6C 04 00 00 00 00 10 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 C9
       -Base Idle
Request to hold 2000rpms then click continue:
From Tech2: F7 6C 04 24 00 00 00 04 00 00 00 00 00 00 00 C5 00 8C 00 00 00 00 00 00 00 20
then Requests to adjust TPS back to desired idle
When exiting: From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D9
-EGR Control
Click increase
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 13 00 00 00 00 00 06
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 26 00 00 00 00 00 F3
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 39 00 00 00 00 00 E0
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 4C 00 00 00 00 00 CD
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 5F 00 00 00 00 00 BA
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 72 00 00 00 00 00 A7
-Reset Cells
From Tech2: F7 6C 04 00 00 00 00 08 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D1
-Bypass Spark
Spark mode is on Bypass…
Clicking EST
Clicking Bypass
From Tech2: F7 6C 04 00 00 00 00 04 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D5
-Air Fuel Ratio
Currently on 14.7 : 1
Clicking increase:
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C4 00 98 00 00 00 00 00 00 00 3D
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C4 00 9D 00 00 00 00 00 00 00 38
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C4 00 A2 00 00 00 00 00 00 00 33
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C4 00 A7 00 00 00 00 00 00 00 2E
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C4 00 AC 00 00 00 00 00 00 00 29
From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C4 00 B1 00 00 00 00 00 00 00 24
-Output Tests
     -Fuel Pump
Turn On: From Tech2: F7 6C 04 40 40 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 59
Turn Off: From Tech2: F7 6C 04 40 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 99
     -A/C Clutch
Turn On: From Tech2: F7 6C 04 20 20 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 99
Turn Off: From Tech2: F7 6C 04 20 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 B9
     -Check powertrain Lamp
Turn On: From Tech2: F7 6C 04 10 10 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 B9
Turn Off: From Tech2: F7 6C 04 10 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 C9
     -High Fan
Turn On: From Tech2: F7 6C 04 04 04 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D1
Turn Off: From Tech2: F7 6C 04 04 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D5
   -Canister Purge
Turn On: From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 08 FF 00 00 C0 00 00 00 00 00 00 00 00 00 D2
Turn Off: From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 08 00 00 00 C0 00 00 00 00 00 00 00 00 00 D1
     -Starter Relay
Turn On: From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 02 00 D7
Turn Off: From Tech2: F7 6C 04 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 02 02 D5
Clicking On Function Tests
-IAC Circuit
Informs user engine must be hot! Cant be cold! (roughly 80degs)
“IAC Will Be Cycled Automatically. Do Not Move the Throttle!”
From Tech2: F7 6C 04 04 04 00 00 00 00 00 00 00 00 00 00 C1 D5 00 00 00 00 00 00 00 00 FB
-02 Sensor (Need closed loop to perform this.. will come back)
-Power Balance
“Injectors will be turned off Sequentially”
(Does a whole heap of frames turning each injector on and off and checks change in rpm)
-Low Fan
Turn Low speed fan request:
On: From Tech2: F7 6C 04 08 08 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 C9
Off: From Tech2: F7 6C 04 08 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D1
Exiting: From Tech2: F7 6C 04 08 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 D1
Postby Micks » Sat Oct 24, 2015 8:07 pm
Guys been reading through posts on adjusting & modding settings on the VY-VZ.
Made some progress using the OSE tool in setting start up symbols & shutdown text on both my Crewman SS & Maloo clusters. Previously sent my SS cluster to a fellow on another forum who made some adjustments for fuel cal & shutdown text, redline etc. Though later found a heap of other settings that were previously fine were now messed up! The SS was a manual though changed to an auto now always showing the P symbol constantly that with intermittant service intervals too. Have used Stoops XL spreadsheet for changing settings like the cold redline shiftup feature. Very keen to do some more with these VZ clusters.
Micks
Postby vpgts076 » Thu Mar 17, 2016 8:18 pm
What Can I say appart from you guys ROCK.
I have been starting out with these clusters.......
Just a Tip if you unlock the cluster then use the AAPL software it opens way more doors.... :)
Can anybody point me in the right direction of downloading a complete bin via AlDl? PLEASE :)
thanks
Daniel
vpgts076
Postby Micks » Mon Nov 14, 2016 4:15 pm
Been a while though with help of a friend have produced a spreadsheet similar to the "stoop" XL sheet getting around the net. So far it will change most desired settings including Fuel guage cal, Temp guage cal, PPK settings, SRS cal & fault reset. Manual/Auto , V6/V8.
Once complete & fully tested, will post up here for anyone to use freely.
Obviously you will need an aldl cable or arduino board etc along with the freeware OSE program which is very reliable.
Micks
Postby CommodoreNut » Sat Dec 31, 2016 11:32 am
TazzI wrote:Im not actually 100% sure on the pinout of the vy/vz clusters. They both differ and neither match up to the pinouts diagrams on carmodder. The vt.vx cluster pinouts do match though if you check the vt/vx specifications section, but looks like you sussed out the pins anyways, Least that one is working!
Iv grabbed a couple harness from vy/vz's and use those instead of the pins, so I only know the wiring colour pinout for the vy/vz.
Yeah looks like a typical response for the vt cluster. Could already see the kms in the responses eg.
F2, 67, 1, 2, 3, 16, 4, 0, 0, 0, 3F, 0, 0, 0, 0, 0, 92, 4, 77, 72, C9,
0x031604 = 202244kms
And also the part number: 92, 4, 77, 72 = 92047772
Not sure why they did they part number like that.
F2, 67, 1, 3, E1, 1, C5, FF, 0, 64, C, E, 18, 8C, 3, E8, 5, 32, 29, 0, 90,
Can also see the speedo cal in there (ppk) = 6284
And table 0 general has what is currently going on, such as which lights are on, engine status, gear status, voltage ect.
Those responses are the "generic" codes that can be obtained from the cluster. I think most main changes can be done there... I think? eg v6/v8,auto/manual, speedo, airbags ect.
But I find it better attacking the direct eeprom location for each parameter.
Try sending F2,57,11,00,chksum. That should send back a seed that you will need a key for.
Done a bit of work on the vt/vx clusters, be good to dig into them some more.
Hi Tazzi
Great work,
Im a newby to this cluster stuff.
I have many yearsexperiance with memcals and ecu flashing ( inc HP Tuners ) as well.
But playing with cluster, BCM's really interests me.
i have a working ALDL cable using OSE flash tool.
Also have a Tech 2 Scanner
Played around with http://757goat.org/gto_cluster/Worksheet.php
now want to get more involved
How can i read Cluster part number and k's through the OSE tool?
Also want to be able to read Air bag setup as well
CommodoreNut
  • In total there are 13 users online :: 0 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 13 guests
