Postby crackers01 » Thu May 24, 2012 9:00 am
Attached is dumps from SS Stereo and OMEGA HCE SZ. CAR is early 2006.
crackers01
Postby crackers01 » Thu May 24, 2012 9:15 am
Jezzab, how much where you chasing for the addresses for the vim removal?.
crackers01
Postby crackers01 » Fri May 25, 2012 10:28 am
Will the willem gq-4x reprogram the 93c66wp chip in the hce? I could read it with the 93c66b setting but could not write to the chip.
crackers01
Postby TazzI » Fri May 25, 2012 10:41 am
From memory you have to take the eeprom off to read it, Grunt had the same problem with the VX clusters with 93C66 eeproms. He managed to get it to write eventually but the write was incorrect, the board sucks too much power when writing.
Postby jezzab » Fri May 25, 2012 12:45 pm
crackers01 wrote:Jezzab, how much where you chasing for the addresses for the vim removal?.
Im not charging for it and im not giving them out sorry mate
Postby 94873 » Thu May 31, 2012 8:34 am
Does anyone know someone in Sydney who reprograms SSV/Calais stereo headunits for SV6?
94873
Postby T2000 » Thu May 31, 2012 12:04 pm
94873 wrote:Does anyone know someone in Sydney who reprograms SSV/Calais stereo headunits for SV6?
Hey mate ... I'm down in Wollongong and can help you out if you can't find anyone closer.
Cheers. Chris
Sent from my Galaxy Nexus using Tapatalk 2
T2000
Been thanked: 4 times
Postby VYSSUTE » Thu Jun 07, 2012 12:57 pm
Hi everyone, 1st post so forgive me if this has been answered some where. With the reprogramming of hvac unit's from sz to dz with that obdi programmer. Is anyone aware of being able to do this with a Tech2?
my tech2 is not currently working and needs a new vci module, so i can either buy the new module or buy one of these obdi programmers.
I would assume i must be able to as it's a factory tool.
Also, people doing the resistor mod do your car's not have ambiet temp sensor on the front of the car?
the reason for asking is because im doing this for my brothers 06 SS with a reprogrammed g8 headunit and this car has the ambiet temp sensor, sunlight sensor for auto headlights and im pretty sure the internal temp sensor allready.
VYSSUTE
Postby ZerOne » Thu Jun 07, 2012 2:19 pm
Hi there VYSSUTE and welcome to the forums :)
I am not too sure about whether you can Tech2 the HCE to re-program it from Single Zone to Dual Zone.
(Holden Dealers apparently cannot carry out a colour head unit conversion, but I do not know what their limitation is).
I know that they can replace a faulty headunit or fascia (So setting the VIN number, and seed keys for the headunit and fascia)...
Soooo I am assuming that they should also be able to re-program the HCE module ?????
I am also assuming that for Holden, the most difficult part is adding the additional wiring for the sensors.
As for the required sensors and the resistor mod....
Another member here MartinM was the member that came up with the resistor mod for the HCE, after discovering that his SS did not have the required sensors (Outside ambient, Cabin temp, and the sunload sensors)....
To clarify, there are two types of sunload sensors, the first is just for the automatic headlights (Daylight Sensor). (Typically fitted to Omega, SV6, and SS models).
The second type also has the above sensor, and an additional drivers side and passenger side sunload sensors, which are solely used by the DZ climate control system. These are a different type to the daylight sensor in that they provide different resistance values to the headlight sensor.
The sunload sensor looks exactly the same, regardless of the model, however the DZ climate control models have 6 pins instead of the usual 2 (or 4, cant remember) pins on the connector....
For the interior ambient temperature, I dont know if Holden snuck them in on later models, but the quickest and easiest way to tell if its fitted is to pull the lower trim off on the drivers side, and check for a 1.5 to 2cm hose that connects behind the trim piece near the little vent hole on the trim piece.
The quickest way to tell if you have an outside ambient temperature sensor fitted, is to see if your HVAC system can tell you the real outside temperature. (A standard feature on both Ford and Holden Climate Control systems going wayyyy back to Ford EA Falcons and VN Series II Commodores)
If the temperature reading is exactly the same, all the time (Give or take 1 degree), then the sensor is not present, and has a resistor fitted to trick the HCE in to thinking it is...
To be honest though, Holden have been very stingy with fitting stuff that isnt required on the VE models, so I really doubt that the required sensors will have been fitted at the factory, or even Holden fitting the required wiring for the sensors.
Finally, one good thing about the HCE module is that if you have any difficulty programming the thing, you can always try and source one from a wrecker. (It doesnt require VIN matching or anything like that)...
Hope this all helps ....
Postby VYSSUTE » Thu Jun 07, 2012 2:32 pm
When i get home this weekend i'll compare whats in my car (ssv) to my brothers. I do recall on the tech2 being able to do the relink for the fascia atleast.
the penny pinching doesnt surprise me but my brothers car was a september 06 build and pretty much came with everything they started pulling stuff out. lol
With any luck the right sensors might be in, if not I'll solder the resistors in.
OT, but most forums my nick is Tre-Cool but i couldnt use the dash so defaulted to an older nick. Jezza will know who i am. :-)
All this work in my brothers car only come about thanks to the original stereo playing up. :lol:
VYSSUTE
  • In total there are 11 users online :: 0 registered, 0 hidden and 11 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 11 guests
