Tremec
T5 (M49) 5 Speed Manual (GM Spec) Specifications
Discuss transmissions manufactured by Tremec such as the T-45, T-56, TR-3650, and TR-6060
Postby ZerOne » Sat Nov 20, 2010 9:49 am
T5 (M49 - GM Spec) Transmission Specifications
Type:
Tremec T5 (M49)
Rear wheel drive, five-speed manual transmission
Engine Range: 3.8L
Maximum Validated Engine Torque: 230 lb-ft
Gear Ratios:
First: 3.75
Second: 2.19
Third: 1.41
Fourth: 1.00
Fifth: 0.72
Reverse: 3.53
Maximum Validated Gross Vehicle Weight: 1931 kg
Case Material: Aluminum
Return to Tremec
