T56 (MM6 - GM Spec) Transmission Specifications
Type:
Tremec T56 (MM6)
Rear wheel drive, six-speed manual transmission
Engine Range: 5.7L
Maximum Validated Engine Torque: 385 lb-ft
Gear Ratios:
First: 2.66
Second: 1.78
Third: 1.30
Fourth: 1.00
Fifth: 0.74
Sixth: 0.50
Reverse: 2.90
Maximum Validated Gross Vehicle Weight: 1680 kg (w/passengers & luggage)
Case Material: Aluminum
