2010 Hydra-Matic 6T70 (MH2) FWD - 06/05/2009
Type: Six speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with an electronically controlled torque converter clutch.
Engine range: 3.5L - 3.6L
Maximum engine torque: 280 lb-ft (380 Nm)
Maximum gearbox torque: 450Nm 1st gear / 515 Nm 2nd-6th gears
Gear ratios: MH2
First: 4.484
Second: 2.872
Third: 1.842
Fourth: 1.414
Fifth: 1
Sixth: 0.742
Reverse: 2.882
Final Drive Ratio: 2.77 ( Effective Final Drive Ratio )
Maximum input speed: Rev 5000 rpm
1-2 7000 rpm
2-3 7000 rpm
3-4 7000 rpm
4-5 6500 rpm
5-6 5798 rpm
Maximum validated gross vehicle weight: 2619 kg (5775 lbs)
Shifter Posistions: P, R, N, D, M, (DSC+/-) & L (MU/MD)
Shift pattern: 6 Variable Bleed Solenoids
Shift quality: 6 Variable Bleed Solenoids
Torque converter clutch: Variable Bleed Solenoid
Converter size: 246mm (reference) (diameter of torque converter turbine)
Fluid type: DEXRON® VI; 9986153; Spec:GMN10060
Transmission weight: wet: 102.0 - 102.4 kg
Fluid capacity (approximate): 9.0L (9.5 qt)
Bottom pan removal: NA
Pressure taps available: line pressure
Transfer design: three-axis design
Assembly sites: Warren, Mich.; Ramos Arizpe, Mexico
Applications:
Buick LaCrosse
Cadillac SRX
Chevrolet Captiva Sport
Chevrolet Equinox
Chevrolet Malibu
GMC Terrain
