by ZerOne » Mon Jul 18, 2011 11:19 am
Hello and welcome to the forums !
As for your question, I am not an automatic specialist, nor have I played around with them much.
From the looks of things, the 6t45 is slightly bigger than the 6t40.
I have no idea the actual dimensions, but from what I have read, the housing has extra ribbing which might effect physically fitting the transmission.
Next, you will need to check the Transmission Control Module electrical connectors from the 6t45, to make sure they are compatible.
The TCM is inside the transmission, and will look after shift feel, shift points and other information.
Sorry I cannot help much more.
I could however look up the workshop manual for your G6, and other GM vehicles with the 6t45 fitted, and try and get some more information for you if you wish ???
