6T40 — 6-speed light-duty FWD
6T45 Specifications
Light Duty FWD Transmission fitted from 2008 onwards
Postby ZerOne » Sat Nov 20, 2010 7:12 pm
2010 Hydra-Matic 6T45 (MH7) 06/05/2009
Type: Six speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with an electronically controlled torque converter clutch.
Maximum Engine power ( hp/kW ) 215 hp ( 160 kW )
Maximum engine torque: 232 lb-ft (315 Nm)
Maximum gearbox torque: 314 lb-ft (425 Nm) - All gears
Gear ratios: MH7
First: 4.58
Second: 2.96
Third: 1.91
Fourth: 1.45
Fifth: 1
Sixth: 0.75
Reverse: -2.94
Final Drive Ratio: 2.89
Maximum input speed: Rev 7000 rpm
1-2 7000 rpm
2-3 7000 rpm
3-4 7000 rpm
4-5 7000 rpm
5-6 7000 rpm
Maximum validated gross vehicle weight: 2200 kg (4850 lbs)
Shifter Posistions: P, R, N, D, M
Shift pattern: Variable Bleed Solenoids
Shift quality: Variable Bleed Solenoids
Torque converter clutch: Variable Bleed Solenoid
Converter size: 236mm (reference) (diameter of torque converter turbine)
Fluid type: DEXRON® VI
Transmission weight: wet: 84 kg (184.8 lb)
Fluid capacity (approximate): 8.12L (6.86 kg)
Bottom pan removal: NA
Pressure taps available: Line Pressure
Transfer design: Three-axis design, Output Chain
Assembly sites: GMDAT, Korea; SGM, China, GMNA, SLP Mexico
Applications (MY2010):
Chevrolet Equinox
GMDAT Tosca
SGM Buick LaCrosse
Buick LaCrosse
GMC Terrain
Return to 6T40 — 6-speed light-duty FWD
