6L45/6L50 6-speed medium-duty RWD
6L50 Specifications
Used in GM Sigma platform cars from 2007 onwards
Postby ZerOne » Sat Nov 20, 2010 7:34 pm
2010 Hydra-Matic 6L50 Transmission ( MYB ) 06/05/2009
Type: six speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
Maximum engine power: 315 bhp ( 235 kw )
Maximum engine torque: 332 lb-ft ( 450 Nm )
Maximum gearbox torque: 480 lb-ft ( 651Nm )
Gear ratios: MYB
First: 4.06
Second: 2.37
Third: 1.55
Fourth: 1.16
Fifth: 0.85
Sixth: 0.67
Reverse: -3.2
Maximum shift speed 7000 rpm
Maximum Validated Weights: ( Target ) GVW: 6613 lb ( 3000 kg ), GCVW: 12505 lb ( 5672kg )
7-position quadrant: P, R, N, D, X, X, X ( X = available calibratable range position )
Case description: 3-piece ( Bell, main, extension )
Shift pattern: (2) Three-way on/off solenoids
Shift quality: Five variable bleed solenoid
Torque converter clutch: Variable Bleed Solenoid ECCC
Converter size: 240, 258mm ( reference )
Fluid type: DEXRON® VI
Fluid capacity: w/258mm converter 9.1 kg
Transmission weight: w/258mm converter wet: 85-90 kg ( 187-198 lb ) estimated
Pressure taps available: line pressure
Assembly sites:
GMPT Strasbourg, France
GMPT Ypsilanti, MI
GMPT Silao, MX
Applications:
Cadillac STS
Cadillac CTS
Cadillac SLS ( China )
Daewoo Statesman
Cadillac CTS Wagon
Chevrolet Camaro
Holden Commodore
Holden Statesman
Buick Park Ave (China)
Available Control Features:
Multiple Shift Patterns ( Selectable )
Driver Shift Control ( Tap Up / Tap Down )
Enhanced Performance Algorithm Shifting ( PAS )
Selectable Tow / Haul Mode
Engine Torque Management On All Shifts
Altitude and Temperature Compensation
Adaptive Shift Time
Neutral Idle
Reverse Lockout
Automatic Grade Braking
Additional Features:
OBDII / EOBD
Integral Electro/Hydraulic Controls Module ( Tehcm )
Control Interface Protocol - GMLAN
Return to 6L45/6L50 6-speed medium-duty RWD
