4T45-E Transmission Specifications
Type:
4T45-E Transaxle (MN5)
Four speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch
Engine Range: 3.0L - 3.4L
Maximum Engine Torque: 215 lb-ft (290 Nm)
Maximum Gearbox Torque: 360 lb-ft (488 Nm)
Gear Ratios:
First: 2.957
Second: 1.623
Third: 1.000
Fourth: 0.683
Reverse: 2.143
Maximum Shift Speed: 5800 rpm
Maximum Validated Gross Vehicle Weight: 1990 kg (4347 lb)
7-Position Quadrant: P, R, N, OD, 3, 2, 1
Transfer Design: Two-Axis design, link chain assembly
Case Material: Die cast aluminum
Assembly Site: Windsor, Ontario
