4T40-E/4T45-E 4-speed light-duty FWD
4T40-E Specifications
Used in smaller front wheel drive GM vehicles from 1995 onwards
Postby ZerOne » Sat Nov 20, 2010 10:07 am
4T40-E Transmission Specifications
Type:
4T40-E Transaxle (MN4)
Four speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch
Engine Range: 1.5L - 3.1L
Maximum Engine Torque: 200 lb-ft (271 Nm)
Maximum Gearbox Torque: 325 lb-ft (440 Nm)
Gear Ratios:
First: 2.957
Second: 1.623
Third: 1.000
Fourth: 0.683
Reverse: 2.143
Maximum Shift Speed: 6500 rpm
Maximum Validated Gross Vehicle Weight: 1990 kg (4347 lb)
7-Position Quadrant: P, R, N, OD, 3, 2, 1
Transfer Design: Two-Axis design, link chain assembly
Case Material: Die cast aluminum
Assembly Site: Windsor, Ontario
Return to 4T40-E/4T45-E 4-speed light-duty FWD
