Swapping SIC main board
Postby torquative » Tue Dec 01, 2015 3:41 pm
Hey all
I picked up a 3-gauge atari style SIC for the costly price of $15 off ebay
Problem is when it got to my place it has a few deep scratches on the LCD panel, which will annoy me if I installed it like that
My question, having popped the black plastic cover off the SIC, it appears the main board is held into place by 4x bent and soldered tabs to the main silver chassis, a couple of clips to the main SIC body, and obviously the LCD ribbon cable also runs to the board.
If I were to swap these main boards, so the 3 gauge board is married to my existing 2-gauge LCD panel and chassis, can I expect any troubles or should it work? Theoretically the LCD is the same, its either the board or the programming of the boards that's different and I'm replacing this in its entirety.
I don't want to go to all the effort of stripping down and rebuilding a couple of SICs if someone knows for a fact that it wont work for some reason, but I'm happy too if someone can confirm it will work so I don't have a few dirty scratches annoying me for the rest of the life of the car.
torquative
Postby Morris70 » Wed Dec 02, 2015 12:14 am
Should work fine, the displays are interchangeable.
The only difference between the 2 gauge and 3 gauge SIC is the firmware programmed into the MCU chip and the eeprom.
Morris70
Has thanked: 5 times
Been thanked: 24 times
Postby torquative » Wed Dec 02, 2015 3:12 pm
ok, well in case anyone in the future has this question
Yes, it works. I swapped the 3 gauge board with the damaged LCD panel from a SS-V to my 2 gauge pristine LCD from the SV6. The soldered tabs are a bit of a pain in the ass to unsolder and bend, I ended up breaking part of the PCB around it, but its all good just bend the tabs back when you swap board over and it fits snug.
torquative
