Transferrin my old radios Bin file to a new one but no bueno
Postby Rbarganier » Wed Jul 01, 2015 1:32 pm
Well my old headunit decided the LCD didnt want to work anymore. A buddy gave me his old unit after I helped him install his Chinese aftermarket clone and I thought I would just take the bin of the old radio and transfer it. YET EVERY SINGLE TIME I try it errors out any ideas? I am using a cheap usb (probably my issue) and this software
https://www.hightail.com/download/bXBZe ... R0dLRmNUQw
The dumps look correct based on the other information I have found on this site.
Also just wanted to know if you guys liked this editor -
http://hex-works.com/eng
Rbarganier
Has thanked: 4 times
Postby TazzI » Wed Jul 01, 2015 5:38 pm
Rbarganier wrote:Well my old headunit decided the LCD didnt want to work anymore. A buddy gave me his old unit after I helped him install his Chinese aftermarket clone and I thought I would just take the bin of the old radio and transfer it. YET EVERY SINGLE TIME I try it errors out any ideas? I am using a cheap usb (probably my issue) and this software
Gday,
Need a bit more info here..
On what radio? Car? Model?
Cheap programmers + expensive parts generally dont mix too well! Iv found that alot of the time, you will need to to power the device up and read out the eeprom.
Or better yet, desolder the eeprom and try read/write ;)
Postby Rbarganier » Wed Jul 01, 2015 10:17 pm
Sorry the Car is a 09 Pontiac G8 GT, V1 stock 6 disk cd changer and going back with the v1 stock 6 disk CD changer. I get the read off the old chip and it verifys yet when I goto the new radio try and erase and reprogram it chip is in dissagreement
Rbarganier
Postby TazzI » Thu Jul 02, 2015 12:53 pm
Rbarganier wrote:Sorry the Car is a 09 Pontiac G8 GT, V1 stock 6 disk cd changer and going back with the v1 stock 6 disk CD changer. I get the read off the old chip and it verifys yet when I goto the new radio try and erase and reprogram it chip is in dissagreement
The radio might drawing too much of the power from the chip when writing. Hence it doesnt work.
Will need to de-solder it and program it off board. ;)
Postby jezzab » Sun Jul 05, 2015 8:56 am
Try it without the Erase. Shouldn't need to erase it just program and verify. If your try and erase I think it will error as it's not supported by that chip from memory. So just get a clean read from the new radio (to make sure the clip is correctly installed), load the old radios bin file and then just program and verify
