VE series II / VF air con compressor help
Postby pir4te » Fri Jun 12, 2015 11:08 am
I have a VE Series II with both clutch and ECVD connectors, but I now have to use Camaro accessories, including air con pump.
Problem is that the new Camaro pump only has just one connector that fits the VE clutch plug. No ECVD connector.
Using one of the two plugs it does starts for maybe a minute until ECU disconnects.
What is the easiest way to terminate the EVCD connector in order for the air con pump to work clutch only?
How can I run the Camaro pump on my VE?
pir4te
Postby TazzI » Fri Jun 12, 2015 3:13 pm
Not to point the obvious, but why not just use a VE air con pump? :?
If you insist on using the camaro one, well best you bring up the wiring diagrams and compare what each pin on each plug does. I imagine something over GMLAN might be triggering on/off so may have some issues there
Postby pir4te » Fri Jun 12, 2015 8:24 pm
I've recently added VVT which meant I had to run accessories 1.5" further forward, so have all Camaro accessories drive.
I will have a look for the VE A/Con wiring diagrams, yes, as the next step. Thanks, BRB.
pir4te
