VE 2007 stereo swap
Postby bubasathish » Fri May 09, 2014 10:40 pm
Hi, Im swapping out my factory stereo for a factory 6 stack stereo. However it just blows the fuse every time I hook it up. The details of my ingoing stereo are... L1 Omega IDC fascia, 92228609 and L2 IRC 92247111.
How do i get around the fuse blowing? Can I just up the 15amp to a 20 amp? Do I have to do something special with the wiring to get around it.
Thanks!!
bubasathish
Postby silversv6 » Sat May 10, 2014 11:42 am
If it's blowing fuses, then it IS blowing fuses..full stop. Upping to 20 amp will not change things except for maybe melting wires. Not sure on the S1 units but I would say there may be a difference in the wiring harness. Search this forum as there may be info on these units. Cheers
If all you guys take the time & do a bit of reading through the forum, you may find exactly what you need! try this link.
view_doc.php?doc_id=67&model_id=19
Postby doubledip » Wed May 14, 2014 4:10 pm
is it a later stereo like a MY9.5 onwards
if it si and its blowing the fuse in the boot then there is a wire that needs removing
  • In total there are 8 users online :: 0 registered, 0 hidden and 8 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 8 guests
