HVAC writing trouble
Postby 69terra69 » Mon Jul 22, 2013 2:30 pm
hey guys im trying to write a dz hvac on my single using the keeprog usb.
so i connect it all up open the dz file then click write and it comes up error out the bounds of the array.
iv tried 3 different computers still the same, also noticed the keeprog software doesn't have the option to choose 93c66mp
any help would be much appreciated.
69terra69
Postby doubledip » Mon Jul 22, 2013 4:32 pm
Sorry cant help you with the exact problem... but I never had much luck writing a successful HVAC Module....
but just a word of advice ... these KEEProg programmers are a piece of CRAP!!... just straight out junk... buy a decent programmer if you want to delve further into this programming stuff...
something like a Willem Programmer
Postby 69terra69 » Mon Jul 22, 2013 6:29 pm
thanks for info
can i just buy a dual zone hvac and install it and job done or does the vin need to be programmed ?
thanks mate
69terra69
Postby doubledip » Mon Jul 22, 2013 6:41 pm
can buy one and just mod as per other articles on here to trick the temp snesors that are missing etc.. no vin
Postby velj » Sat Jul 27, 2013 3:23 am
Dw mate ur not the only one I got the programmer you have to and it says the same thing for me! Still can't work it out!
velj
Postby ZerOne » Sat Jul 27, 2013 9:19 am
I was playing around with the keeprog software recently on Windows8
(Yeah, I know, only the insane use that windows 8 pos).
Anyway I could fix the array out of bounds error by running with admin privileges.
This probably won't help you too much with the HVAC module, as it is a pain to program the eeprom on these things.
Your best bet is like what double dip said, get a good quality william programmer, and desolder the eeprom chip to read and write to it.
Having said that, there are different eeprom versions for different sw and hw versions.
So I would suggest that you just obtain a HVAC module from a dz model, and use that as your base.
Sent from my Nexus 10 using Tapatalk HD
Postby Luminass » Sat Jul 27, 2013 12:37 pm
Has anyone tried with a jtag
Luminass
