VE headlight switch illumination colour change
Postby AndreasB » Wed Feb 27, 2013 8:56 am
Hi, im in the process of changing the switch and dash illumination from red to white in my VE SSV ute. Ive done everything so far but the headlight switch is causing me grief. Ive popped the back cover off, but I cant get the circuit board out.
Has anyone managed to get one apart without breaking it?
Thanks Andreas
AndreasB
Postby Morris70 » Wed Feb 27, 2013 10:44 am
changed mine from green to white a while back, I used 3 flat head screwdrivers spaced equally around the bottom of the shaft and just gently prised it off.
Once the shaft comes out you can remove the pcb.
You'll need 6 x plcc2 leds to change the colour
Morris70
Has thanked: 5 times
Been thanked: 24 times
Postby AndreasB » Wed Feb 27, 2013 12:18 pm
Great, thanks for the info, ill give it a go as soon as I can!
AndreasB
Postby AndreasB » Wed Feb 27, 2013 5:27 pm
You legend, that worked! I wasn't levering it hard enough before, I thought I'd break it! This time it popped off and I've changed the leds over.
Thanks very much!
Cheers Andreas
AndreasB
