Ok, I have kind of bummed out on some things, and made progress with others..
1) I may have fried my backup fascia (The one with the EEPROM plug soldered on board.
When I tried using it on both my original HVAC main unit, and my backup HVAC unit, it did nothing.
(It didnt light up, the buttons were not responding, it was totally DEAD)
I am hoping that it is something as simple as a bad solder joint, or a track for the EEPROM has been damaged.
2) My backup HVAC main unit works, but I couldnt test the VIN setting, as you need the fascia programming to match the main unit for everything to work. Because my backup fascia isnt working, I dont have a fascia that matches the Backup unit. (Unless I Upload the backup fascia EEPROM data to my main fascia, but I REALLY dont want to mess with my original gear at this time.
3) Using the backup main unit, with my original fascia, the background colors were red (Like SS and HSV models), not blue like Calais models....
So this is telling me that the background colours and possibly startup screen logos may be held in the man unit EEPROM after all ? (Unfortunately I need to get my backup fascia working to know for sure.
4) i did some tests on the VGA input...
OK, this one is going to be tricky. For the input to work, you need the GMLAN to NAV Module connected.
Whether this broadcasts on the GMLAN that a Nav module is fitted, or whether it listens for a NAV startup request, I dont know, but I don now know that when its disconnected, Pressing the NAV button on the Radio does nothing.
It doesnt bring up a VGA blank screen, it doesnt switch On r off the radio, it just becomes a dead button,
So if you want to use the VGA Video input for an in car PC, we need to work out what this GMLAn Module does exactly.
