First Generation Automatics (3 Speed)
3T40 Specifications
Includes Front and Rear Wheel Drive Automatics such as 3L and 3T Series of Automatics
Postby ZerOne » Sat Nov 20, 2010 10:15 am
3T40 Transmission Specifications
Type:
3T40 Transaxle (MD9)
Three speed front-wheel-drive, automatic transaxle with mechanical torque converter clutch
Engine Range: 2.2L
Maximum Engine Torque: 200 lb-ft (271 Nm)
Maximum Gearbox Torque: 390 lb-ft (530 Nm)
Gear Ratios:
First: 2.840
Second: 1.600
Third: 1.000
Reverse: 2.067
Maximum Shift Speed:
1-2 6200 rpm:
2-3 6200 rpm:
Maximum Validated Gross Vehicle Weight: 2318 kg (5100 lb)
6-Position Quadrant: P, R, N, D, 2, 1
Transfer Design: Two-Axis design, link chain assembly
Case Material: Die cast aluminum
Assembly Site: Willow Run - Ypsilanti, MI
Return to First Generation Automatics (3 Speed)
