LN2 2.2 Litre OHV 4 Cylinder Powerplant
LN2 Specifications
Discuss the 2.2 Litre OHV Inline 4 Cylinder Engine from GM
Postby ZerOne » Fri Nov 19, 2010 9:44 am
LN2 Engine Specifications
Type: 2.2L L4 LN2
Displacement: 2189cc
Compression Ratio: 9.0:1
Valve Configuration: Overhead Valves
Assembly Site: Tonawanda, NY
Valve Lifters: Hydraulic Rollers
Firing Order: 1 - 3 - 4 - 2
Bore x Stroke: 89.00 x 88.00mm
Horsepower: 115@5000 rpm
Torque (lb-ft): 135@3600 rpm
Fuel Shut Off: 6000 rpm
Emissions Controls:
Evaporative System
Catalytic Converter
MATERIALS
Block: Cast Iron
Cylinder Head: Cast Aluminum
Intake Manifold: Composite
Exhaust Manifold: High Silicon Molybdenum Cast Nodular Iron
Main Bearing Caps: Cast Grey Iron
Crankshaft: Cast Nodular Iron
Camshaft: Assembled Steel with Powder Metal Journals
Additional Features:
Extended Life Spark Plugs
Extended Life Coolant
Return to LN2 2.2 Litre OHV 4 Cylinder Powerplant
  • Most users ever online was 948 on Sat May 11, 2024 8:08 pm
