Photoshop Forums
MMOexp-POE Best Atlas Trees for Expedition
A place to request or post your photoshop modified rides and ideas
Postby Chunzliu » Wed Jul 02, 2025 12:43 pm
If you're diving into Path of Exile 3.26 Secrets of the Atlas and feel overwhelmed by the endless passive tree decisions, map sustain issues, or figuring out what content to prioritize-guide is here to rescue your league start and set you up for big profits.
In this deep-dive, you'll learn:
How to efficiently set up your starter Atlas for fast progression
Tips to sustain and expand your map pool
Multiple specialized profit Atlas trees focused on Expedition POE currency, Delve, Essences, and more
Whether you're in Hardcore, Softcore, SSF, or Trade, this guide is packed with practical advice to elevate your early game.
The 27-Point Starter Atlas: Mapping Made Simple
Your first priority in any league is Atlas progression and map sustain. 27-point starter tree takes a streamlined path directly to Commission Officer, prioritizing map completion bonuses and basic sustain.
Key Highlights:
Carrot Completion Nodes: Help you unlock more completion bonuses via Kirac.
Scouting Reports: Boost your ability to target maps and gain consistency.
Map Upgrading Mechanics: With nodes that give a 100% chance for a map drop to be +1 tier higher, your low-tier maps instantly upgrade your map pool.
Blighted Scouting: Extra cherry on top; not mandatory, but helpful.
Pro Tip: These sustain-focused nodes are invaluable early, but become optional once you're fully juicing maps and upgrading via Voidstones.
Kirac Tips for Fast Completion
Map sustain hinges heavily on Kirac missions and shop usage:
Alt+Hover on maps in his shop to see which ones you haven't completed.
Don't worry about the missions themselves-focus on getting new completions.
To force a Kirac shop reset, simply complete a map, then revisit his menu.
Utilize 3-to-1 map vendor recipes: Trade three maps of the same type to create a random natural map of one tier higher.
Example:
Selling 3 Precinct maps gives a random natural Tier 8. Swapping just one map can change the result-each item ID matters. Play around and you'll quickly learn how to manipulate results to finish your map grid faster.
Why You Shouldn't Always Block Mechanics Early
Blocking consumes passive points and can reduce chances for unexpected profit:
Ritual Monsters can drop Omens, like Treasure to Treasure (guarantees unique drops).
Ultimatum is worth blocking for scarab optimization, but Ritual can be left alone for free value-especially once your character is tanky.
If you're not specced into Legion, Harvest, or Breach? Simply don't engage with them, rather than waste points blocking them. Focus on your chosen farm-maximize return per hour.
Early Power with Niko, Shrines, and Sulfite
Starter Atlas also makes early progression smoother with a Niko Shrine combo:
Shrine nodes give burst power with Acceleration, Echoing, and Brimstone Shrines.
Niko passive: Every Sulfite click grants +1 max res, 35% increased damage, and 15% movement speed for 60 seconds.
This adds over 100% extra DPS and massive survivability in early red maps.
Bonus: You don't need to actually run Delve-just sell resonators for passive income while mapping.
Also, Divination Card: A Note in the Wind (Niko-exclusive) grants 10 Alterations. If you spec into Niko early and consistently, you can earn hundreds of Alts passively.
Expedition Profit Tree
One of the best early-league strategies is running Expedition, and Ren's tree delivers:
All Expedition nodes + Roiling Grounds for better density
Scarab Chance for juiced runs
Shrines and Sustain help boost map pool and survival
Tujen & Dannig Focus: Best for raw currency and logbooks
Rog: Crucial for crafting mirror-tier rares (especially with his "upgrade all mods" event)
Extreme Archaeology is optional. If it's making maps too rippy, you can path around it. It's good-but not mandatory.
Essence Farming: The King of Currency
Essences are always in demand, and Ren shows how to build an Atlas tree that prints currency with:
Amplified Energies: Guarantee highest tier (Deafening) Essences
+1 Essence Monster and Boss Infusion: More monsters, more profit
Crystal Imprisonment: 3 extra Essences on some mobs (warning-very rippy)
No Scarabs Needed: You can scale this tree with essence scarabs later for even more return
Tip: Tier 6 maps are the sweet spot. You'll still get top-tier essences without making the fights suicidal (like in T16s).
Ren even helped some RuneScape community managers go from 0 to 200 Chaos in a few hours just by farming Essences using this strategy. It's low entry, high payout.Profit Tree Flexibility and Pivot Options
Tree is modular, allowing you to pivot:
Expedition → Betrayal (with minimal node changes)
Niko/Delve → Scarabs/Harvest
Essence → Map Boss Farming
This allows you to adapt based on market shifts, gear needs, or whether you're burning out on a mechanic.
Final Takeaways: Secrets of a Successful Start
If you're overwhelmed by POE's Atlas tree, remember:
1.Start with Sustain: Complete your map pool and unlock Voidstones.
2.Build Early Power: Use Sulfite + Shrines + Scouting for smooth clears.
3.Pick a Profitable Mechanic and commit: Expedition cheap POE currency trade, Essence, or Harvest are top-tier.
4.Don't Over-Spec or Over-Block: Focus on depth, not breadth.
5.Track Results and Pivot: Be flexible as the league economy changes.
Chunzliu
Return to Photoshop Forums
