Rear parking sensor problem
Postby irobson » Wed Jul 09, 2014 3:41 pm
I have a 2006 VE Berlina. The rear parking sensors stopped working after moisture finally dried out of the driver's door actuator which had caused a "door ajar" warning light instance.
Upon entering the menu I am now unable to access the sensor settings. The item simply does not exist in the menu.
irobson
Postby irobson » Fri Jul 11, 2014 10:45 am
Problem solved! Disconnected battery for 30 minutes. Upon reconnecting, menu item has reappeared and rear sensors are now working correctly.
irobson
