VE/G8 Cluster Telematics/Scan Gauge
Postby jezzab » Thu Nov 21, 2013 2:53 pm
Thought I would share with you guys a little project I'm working on. Ive built the hardware and programmed the embedded software to output telematics information to the DIC/Cluster using the information from PID on the HSCAN bus. Can chime for upshift or if the Knock Retard is too high etc. The idea is to just plug the dongle into your OBDII port or hard wire it in if you want.
Effectively its a HS CAN / GMLAN Bridge with packet alteration and formatting
Vid should explain it all...
https://www.youtube.com/watch?v=kUIEAp0dkTA
Postby advancedservers » Thu Nov 21, 2013 11:41 pm
Looks awesome Jez, great work.
advancedservers
Has thanked: 2 times
Postby SteveG8 » Fri Nov 22, 2013 7:51 am
Nice work Jez.! No wonder you've been so quiet lately ;)
hmm now where did that Thumbs-Up Button go?? Did Matti turn it off?
SteveG8
Has thanked: 35 times
Been thanked: 14 times
Postby TazzI » Fri Nov 22, 2013 11:20 am
SteveG8 wrote:Nice work Jez.! No wonder you've been so quiet lately ;)
Was just thinking that too. thought it was just me that lost it.
Postby ghodge » Fri Nov 22, 2013 2:49 pm
Very nice!!! Hmmh. Getting some ideas here.
ghodge
Has thanked: 3 times
Postby jezzab » Fri Nov 22, 2013 5:09 pm
Postby jezzab » Fri Nov 22, 2013 7:28 pm
Get this sorted then look at a J1850VPW to ALDL bridge for the VY/VZs
Postby TazzI » Sun Nov 24, 2013 11:52 am
jezzab wrote:Get this sorted then look at a J1850VPW to ALDL bridge for the VY/VZs
Very impressed Jez! :D
Pitty the vy/vz's cant display the text so easily. I was messing with this before, You can manipulate the radio messages to display on DIC but its not as "nice" looking compared to the VE's.
Postby jezzab » Wed Nov 27, 2013 3:41 pm
Latest build. Added a menu to select which PIDs from a pre-defined list you would like to view in the loop
https://www.youtube.com/watch?v=nQDdIJ36vGA
Postby gsuggett » Mon Dec 09, 2013 4:30 am
Amazing! Looks good buddy. One of these days I will have to start messing with more than just clusters. If you start making/selling parts I for one would be willing to pay. So many people here put time in effort into these cars and they should rewarded somehow.
Greg
gsuggett
Images: 8
