Can you Minimise or Disable Stability Control HSV 307 LS2 ?
Postby VEGTS06 » Thu Oct 03, 2013 12:25 am
I have recently brought a HSV GTS 06 with a LS2 in it and my Stabiltiy control button doesn't seem to make much of a difference in minimising the stability control. A few times now it has nearly caused me to crash well swing around.. I have never had it before on any other car I have owned and don't see why it can't be switched off all together? Is it possible? Thanks
VEGTS06
Postby doubledip » Thu Oct 03, 2013 12:52 pm
pressing the button turns it off
Postby silversv6 » Fri Oct 04, 2013 12:27 am
VEGTS06 wrote:I have recently brought a HSV GTS 06 with a LS2 in it and my Stabiltiy control button doesn't seem to make much of a difference in minimising the stability control. A few times now it has nearly caused me to crash well swing around.. I have never had it before on any other car I have owned and don't see why it can't be switched off all together? Is it possible? Thanks
If you had a FIAT 850 or a DATSUN SUNNY then you would find they won't swing around!! & they don't need traction control because they don't ever break traction. Maybe the power & torque is way more than you are used to. OR the problem may be the loose nut behind the wheel.
Postby grantsaylor » Tue Dec 15, 2015 2:54 am
I changed my bcm and stereo then somehow it completely turned my trac/stability control off and abs
grantsaylor
Postby jezzab » Thu Dec 17, 2015 6:29 am
It's off now because there is a fault with the ESP/ABS system. Wouldn't want to have a crash and they find out there is an issue with the system
Postby doubledip » Thu Dec 17, 2015 6:50 am
If you changed your bcm and stereo and did no programming with anything then your abs and airbags will have a code
The brake pedal needs to be relearnt and the Sdm key needs to be relearnt
Otherwise as Jez said those systems won't work and if in an accident insurance companies can wipe you as they have the know how to see what's changed etc
