Ecu pin diagram?
Postby velj » Sun Feb 24, 2013 12:14 pm
Hey guys looking for a pin diagram or something for a ve sv6 sidi 2010 model,
I need to no what wires coming out of it is going to the o2 sensors
velj
Postby radrace19 » Wed Feb 27, 2013 8:24 am
I have it in front of me.
Which engine is that?
LF1, LLT, or LY7?
Edit I'll just put them all up. :)
LF1
Connector 2
Pin - Wire - Circuit - Function
1–2 - Not Used
3 - 0.5 TN - 808 - Low Reference
4–9 - Not Used
10 - 0.5 PU/WH - 1665 - HO2S High Signal (Bank 1 Sensor 1)
11 - 0.5 PU - 1666 - HO2S High Signal (Bank 2 Sensor 1)
12 - 0.5 PU - 3120 - HO2S High Signal (Bank 1 Sensor 2)
13 - 0.5 PU - 3220 - HO2S High Signal (Bank 2 Sensor 2)
LLT & LY7
Connector 1
67 - 0.5 BN/YE - 1664 - HO2S Low Reference (Bank 2 Sensor 1)
70 - 0.5 PU - 1666 - HO2S Reference Voltage (Bank 2 Sensor 1)
71 - Not Used
72 - 0.75 L-GN - 3212 - HO2S Heater Low Control Bank 2 Sensor 1
92 - 0.5 PU/WH - 1665 - HO2S Reference Voltage (Bank 1 Sensor 1)
93 - 0.5 BN/RD - 1667 - HO2S Low Reference (Bank 2 Sensor 1)
94–95 - Not Used
96 - 0.75 GY/WH - 3113 - Heater Low Control Bank 1 Sensor 1
Connector 2
7 - 0.75 GY/WH - 3122 - HO2S Heater Low Control Bank 2 Sensor 1
20 - 0.75 OG/WH - 3223 - HO2S Heater Low Control (Bank 2 Sensor 2)
23 - 0.5 BN/GN - 3121 - HO2S Low Signal (Bank 1 Sensor 2)
24 - 0.5 BN/RD - 3221 - HO2S Low Signal (Bank 2 Sensor 2)
38 - 0.5 PU - 3120 - HO2S High Signal (Bank 1 Sensor 2)
51 - 0.5 PU - 3220 - HO2S High Signal (Bank 2 Sensor 2)
That should be what you need.
-Greg
2009 G8 GXP
586 rwhp - LS3, Cam, TVS2300
radrace19
Postby velj » Wed Feb 27, 2013 6:26 pm
Sorry was for te LLT
Your a legend thank you!!!!
velj
  • In total there are 206 users online :: 0 registered, 0 hidden and 206 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 206 guests
