Postby ghodge » Tue Mar 27, 2012 6:06 am
jezzab,
I found my notes from my last bus sniffing session where I saw what gets sent when the scroll wheel is scrolled up and down while the button is pressed:
10 0D 00 60 01 00 xx 00
where when scrolling up xx is the detent count and for scrolling down it is 0x20 - detent count.
George
ghodge
Has thanked: 3 times
Postby jezzab » Tue Mar 27, 2012 6:34 am
I can see what gets sent with the scroll wheel, when it's changed to AUX I can see what too etc but i can't send to the DIC. Well I can but it doesn't seem to listen all the time. I really think its the newer cluster.
I've tried bracketing the packets with packets from the ecu as seen in TMKs blog but to no avail. I've tried waking up all of the nodes and that just clears the text.
I've gotta do some sniffing and see what the radio is sending when I move the volume etc as there must be more. I THINK maybe the older clusters would accept half the commands and still display but the new ones as very strict.
Anyone got a good Arduino and can us shield logging program that I can output to the debug serial port. I've had a play with the scantool in your program but I have to keep playing with it.
Postby jezzab » Tue Mar 27, 2012 7:14 am
tmk wrote:Howdy - New around here but old to GM LAN.
I did a bunch of hacking with the G8 about a year and a half ago - built an integrated ipod adapter. Helped ghodge with some of his work. http://gmlanhack.blogspot.com
Be more then willing to help out and share anything I have done here. I have an 08 G8 GT, and a bunch of GM LAN log file from when I was doing the ipod work. Can always get more too, plus I can test GM lan messages via the CAN shield and arduino setup I have. Some GREAT work happening here.
TMK
Welcome TMK. Read your blog about 6 months ago top to bottom and got me very very interested in GMLAN :)
Postby ghodge » Tue Mar 27, 2012 8:09 am
I'm glad to see you on here TMK just days after I was made aware of the site. I've since given them a copy of the GPL'd code and posted some links (yours included). The more eyes and coders the better.
George
ghodge
Postby jezzab » Tue Mar 27, 2012 4:36 pm
Well I just plugged it into a 2006 VE with an infotainment unit and it works like a charm. I noticed the cluster is very different to the later ones that it shows the volume change in the middle of the screen vs the top line like mine.
Will try my old cluster tonight and test it.
Oh and I tried a MY12 Holden with the IQ head unit and it doesnt work at all.
Postby jezzab » Tue Mar 27, 2012 7:04 pm
Hacked the code up a little and got it to send to the debug serial port of the arduino so I can have atleast some idea whats going on.
Ive attached a log of me scrolling the volume up and down that I would love you to have a look at. I can see it sending the command to the cluster DIC
Head: 1030C080 Length: 8 Message: 45 2 1 56 6F 6C 75 6D
is "Volum"
and
Head: 1030C080 Length: 8 Message: 44 2 65 20 31 31 4 0
is "e 11"
so "Volume 11"
So im sending
Header: 1030C081
Message: 45 01 53 63 72 44 6e 04
which should be a single packed message of "ScrDn"
but no go on my cluster unless I move the radio controls etc. I notice in your blog TMK that you show the framing packets yet they are not used in the code provided. I also notice (in my log) that these packets are a bit different to yours. Same header (10306060) but the data is
97 0 1
91 0 7
95 0 1
94 0 1
Its like the cluster needs a VNMF wake up but I tried waking them all up and it clears the screen but I did notice in the log:
Head: 624 Length: 8 Message: 0 8 0 0 0 0 0 0
Head: 621 Length: 8 Message: 0 7F 0 0 0 0 0 0
But 621 is the BCM from what ive read but i dont know what 624 is.
Sorry about the rambling jibberish but ive actually had some time to play with this again and its very very close. If you put a newer cluster in an older car the radio displays fine so it must be the way that we are sending to it and leaving some things out and the newer clusters dont accept it. I figure if I can get it working on mine it will be backwards compatible with the older ones
Postby tmk » Tue Mar 27, 2012 11:47 pm
Jeezab,
Send me a section of your log - I'll take a look. 2 eyes are better then one!
TK
tmk
Postby jezzab » Wed Mar 28, 2012 7:14 am
tmk wrote:Jeezab,
TK
I attached it but it didnt attach for some reason. Ill do it again.
Yup that worked that time
Postby tmk » Wed Mar 28, 2012 8:26 am
K.. Looking at what you posted - I think I clipped the DIC stuff only here:
*Head: 1028A080 Length: 2 Message: 0 0
*Head: 1030C080 Length: 8 Message: 45 2 1 56 6F 6C 75 6D
*Head: 1030C080 Length: 8 Message: 44 2 65 20 31 30 4 0
*Head: 1030A080 Length: 6 Message: 0 4 48 C0 0 3
*Head: 1030A080 Length: 6 Message: 0 4 49 40 0 3
*Head: 10306060 Length: 4 Message: 0 97 0 1
*Head: 1030C080 Length: 8 Message: 44 2 65 20 31 31 4 0
*Head: 10306060 Length: 4 Message: 0 91 0 7
*Head: 1030A080 Length: 6 Message: 0 4 48 40 0 3
*Head: 1030A080 Length: 6 Message: 0 4 49 0 0 3
*Head: 10306060 Length: 4 Message: 0 95 0 1
*Head: 10306060 Length: 4 Message: 0 94 0 1
*Head: 1030C080 Length: 8 Message: 44 2 75 78 4 0 0 0
Also - it looks like your scanner is dropping packets?
http://gmlanhack.blogspot.com/2010/12/untested-clarification-of-pontiac-g8.html
I think your newer DIC needs all 3 arbIDs - My old (2008 Pontiac) one didn't.
Arbitration ID 0x183 : Arb_Text_Display_Status
Packet Size: 4 bytes
29bit CAN header
header: 0x10306060
Arbitration ID 0x185 : Arb_Text_Req_Set_Disp_Parameters
Packet Size: 6 bytes
29bit CAN header
header: 0x1030A080
Arbitration ID 0x186: Arb_Text_Req_Set_Display_Text
Packet Size: 8 bytes.
29bit CAN header
header: 0x1030C080
There is another way maybe but I'd like to PM you on that. PM me because I don't have PM yet here..
TMK
tmk
Postby ZerOne » Wed Mar 28, 2012 9:42 am
Hi there tmk !!!
Welcome to the forums !!!!
I have been a long time reader and a huge fan of your gmlanhack blogspot,
http://gmlanhack.blogspot.com.au/
Actually your blog was one of the deciding factors to buy a VE Commodore (Pontiac G8) :D
I have made some changes to your account, so you should be able to P.M. people, as well as see the contributors forum as well.
If there is anything else I can do for you, or if there are problems with the PM settings, then please feel free to let me know.
People with knowledge like yourself are the lifeblood of this forum, and as such I want to do me very best to make you, and other contributing members feel as welcome here as possible.
