Postby SteveG8 » Sat Feb 02, 2013 3:01 am
Ah - that's pretty sneaky! lol Nice :)
SteveG8
Has thanked: 35 times
Been thanked: 14 times
Postby foxdie » Mon Feb 04, 2013 10:43 pm
Well, I've managed to capture packets of 90-95% of actions that can be completed with a dual zone climate control unit (from a Vauxhall VXR8 aka HSV Clubsport R8 E1). I'm now decrypting what each bit / byte does now.
I want to start adding data to the GMLAN Bible, I've dropped tmk a private message requesting read/write access, once the informations in there I'll post up a confirmation here :)
Jason "Foxdie" Gaunt
foxdie
Been thanked: 3 times
Postby foxdie » Thu Feb 07, 2013 3:37 am
The GMLan_Bible has been updated with some more info, and will continue to be updated as I sift through this data :)
foxdie
Postby silversv6 » Wed Feb 13, 2013 10:21 pm
Hey guys, I would say you know what these are used for. can you enlighten me a little....Thanks, cheers
http://sailesmarketing.com/products/can ... interface/
Postby doubledip » Wed Feb 13, 2013 10:25 pm
The CB28800 CAN Bus interface is designed to provide a vehicle speed signal for vehicles using a CAN Bus system
tells you right there :) will be reading the VSS PID on the HSCan and turning it into a usable speed output on a single wire... you buy these through holden as well... they have then for the VE commodore for TAXI's so they can get a speed input into their meters
Postby foxdie » Wed Feb 13, 2013 10:26 pm
silversv6 wrote:Hey guys, I would say you know what these are used for. can you enlighten me a little....Thanks, cheers
Not sure this is the correct place for that question, but I'll answer it anyway. That module listens to vehicle speed data sent across CAN BUS (not specific to GMLan however) and outputs a vehicle speed signal (aka VSS, a pulse train to indicate vehicle speed) for connection to an aftermarket speedometer or another device that requires a VSS.
In short, it lets you use an aftermarket speedometer that isn't CAN BUS compatible with cars released within the last 5 years.
foxdie
Postby foxdie » Wed Feb 13, 2013 10:32 pm
Also worth noting, the GMLan_Bible has been updated yet again with information on HVAC (Climate Control), there's sufficient information there now to build a replacement HVAC controller so you can replace the god-awful head unit :D
I'm still adding more info to the HVAC entries (its a lot of effort sifting through the data, trying to work it out, major logic puzzle), but once it's complete I'll write a proof-of-concept HVAC Controller Replacement for mbed C++, which some other kind soul can probably translate to Arduino's Wiring programming language ;)
Watch this space!
foxdie
Postby silversv6 » Thu Feb 14, 2013 10:56 am
Thanks, I just didn't realise that these later model cars don't give out a vs pulse that can be easily used like the vn commodores. Both excellent clear explanations (doubledip-foxdie), makes it a lot easier for us old schoolers. Cheers.
Postby jezzab » Thu Feb 14, 2013 6:37 pm
Any one stepped it up and moved over to 11bit GMLAN instead of 29bit?
29bit is great and you can simulate commands the module is sending but that's it. 11bit you can program the modules via software, request data that's stored in its chips (even the ones that dont have an EEPROM), write config changes (VIN, VIM, options etc etc)
Anyone wanting to have a play I'd suggest reading GMW-3110 2010 edition.. Good read
Just surprised no one is on it? Or posting about it ;)
Postby foxdie » Thu Feb 14, 2013 6:53 pm
jezzab wrote:Any one stepped it up and moved over to 11bit GMLAN instead of 29bit?
It might be because there's a lot~ of information still un-deciphered in the 29-bit realm. I do realise all the juicy bits are in the 11-bit realm, I've taken a look at GMW-3110 (2010 edition) but makes my eyes bleed and brain turn into that of a cabbage :D
One day I'll get my head around it. Hoping someone else can get there first then explain it to me ;)
Ps. Anyone aware of a document that actually explains what each 29-bit frame is? That'd help us build up the GMLan_Bible so much quicker!
foxdie
