Need help asap car won't start after head unit swap
Postby jezzab » Mon Mar 18, 2013 6:23 am
silversv6 wrote:The easiest way to check your battery is turn on the headlights & crank the car over & if the lights dim severly or go out, then the battery is normally screwed. !
Spot on. Auto lekky trick 101. Or high beams on and crank will load test it as much as you can
Postby velj » Wed Mar 20, 2013 10:18 am
Thanks guys, you learn something every day haha
velj
Previous
