Postby TazzI » Sun Apr 22, 2012 11:35 am
Zero would be:
869 343 - 869343 = 0 ( add 869343)
177777 + 869343 = 1047120
1047120 / 16 = 65445
hex value = FFA5
Still need you to try this Grunt asap!
Postby gruntly69 » Sun Apr 22, 2012 3:44 pm
LMAO, was up till 2am last night & also in a backwards way I figured it out but not as accurate as yours!
I was going to try a decimal value of 55555 x 16 next & thought it would be somewhere around 150,000Kms?
But your logic is a lot better & more accurate so I'll possibly get a chance when at workshop tomorrow!
If anyone has any tips on desoldering with wick or anything it would help!
Nice work TAZZ!!!!!
gruntly69
Postby gruntly69 » Sun Apr 22, 2012 4:29 pm
Would be nice to figure the logic behind how the hell 177776 equals 869,344?
I couldn't find any correlation?
gruntly69
Postby jezzab » Sun Apr 22, 2012 5:29 pm
for Intel AB28f400B5 chips which is a PSOP 44 Pin chip, I use a gas soldering iron with the blower tip. I put something on the top of the chip to help as a heatsink. Heat the legs on one side while gently applying pressure to lift it. repeat for the other side. I can get em off in about 2 minutes and they look like new. DO NOT apply alot of pressure lifting or you will lift the track/pad off the PCB.
Postby aumatt » Sun Apr 22, 2012 5:40 pm
Try this seemed to work on the values given.
Say you want 100,000km
Add 1440 to it (101,440)
Divide by 16 (6340 or 0x18c4)
Minus that figure from 0xFFFF (0xFFFF - 0x18C4 = 0xE73B)
so 0xE73B should be the start of the 16 word odo amount.
Let me know how it goes as I only have a couple of VT clusters in pieces at the moment and not set up for my test bench.
Postby TazzI » Sun Apr 22, 2012 6:51 pm
Yeah Matts way works.
Probably is the Proper way of calculating. Is also quicker!
Mine was a simple backwards calculation. Either way works
Postby aumatt » Sun Apr 22, 2012 7:11 pm
VDO clusters in aus seem to follow similar encryption across cluster to a point from what I can tell.
Postby gruntly69 » Sun Apr 22, 2012 9:05 pm
Thanks Jezza, Matt & Taz... will give it a go tomorrow hopefully & let you know!
same with this section as the VY-VZ would be great to get some other locations for stuff too...
gruntly69
Postby TazzI » Sun Apr 22, 2012 9:28 pm
Seems I should invest into a vx cluster and have a tinker!
Although, my programmer can't read 93Sxx eeproms.. only 93Cxx eeproms.
May have a look around for yours grunt. Unless anyone can suggest different?
Well dont know what else to search for in these clusters! guess we figured out the most important part I guess.
Did a comparison between the single and triple cluster dumps... but the difference between the two don't really give much to go on!
Postby gruntly69 » Mon Apr 23, 2012 1:57 pm
PROOF!!!!!
I was aiming for 148690, but as that's not divisible by 16 I went as close as possible aimed for & got 148690Kms!
Just to know too the 55555 that I was going to put in I think would have achieved 148260Kms if my reverse maths is right, not bad for rough guestimate at 3am sat morning!
Does your programmer support L series EEPROM Taz? I read on another forum it reads/writes same as these eeproms?
But yeah can get a gq3 delivered on eBay for under $100!
gruntly69
  • In total there are 3 users online :: 1 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Majestic-12 [Bot] and 2 guests
