GM ALDL Logging and Scanning
Postby jezzab » Sun Jun 17, 2012 5:31 pm
The MSVBxxx.dll is just the visual basic run time library mate. It's with every vb program. It handles strings, dialogs etc. no use looking in there
The password is calculated though an algorithm in the main exe
Postby Biggsy » Sun Jun 17, 2012 6:33 pm
Looks like you can have as many users as you want, they probably have an algorithm calculator the can put your username into to generate a password to give you the level access they want you to have.
I you type your name into the username box and leave the password box empty, you come up as the registered owner but with default access.
Dave.
Biggsy
Postby jezzab » Mon Jun 18, 2012 12:53 pm
Just make sure that you did go the right place and not just the case statement for the selection of the name to be displayed in the title. because thats what the case statement i showed in the screenshot. It wont unlock any other features, just make the title different
Postby TazzI » Mon Jun 18, 2012 3:14 pm
Ah.. you might be right there Jezza, Using the step functions shows that its already locked in to go down the "default path".. I think!, Will need to trace back to the start and see where if goes from there.
Postby Biggsy » Mon Jun 18, 2012 7:12 pm
Holy crap Tazzi! You da man! lol
Well done.
Biggsy
Postby jezzab » Mon Jun 18, 2012 7:19 pm
Did you fine the case statement in the software? If I knew the area I could add a jmp command etc and make a little patch program or just hex edit the exe
Postby Biggsy » Mon Jun 18, 2012 9:04 pm
Just a bit of a warning for everyone, if you playaround with the "disable eeprom security" command and then try some write commands (manually through tp5 etc) you can corrupt the eeprom!
I found out the hard way and now have to desolder the chip and rewrite it (my eeprom clip hasn't arrived yet)
The cluster is totally non-responsive in every way! lol.
Dave.
Biggsy
Postby TazzI » Sat Jun 23, 2012 7:56 pm
Possibly too many writes wipe the eeprom? (security measures)
Or found a command that wipes the cluster?
There is a reset cluster form in there that I unlocked in the program..
Will need to stumble across the very start of the program and step through each line of the program.. Hopefully find another if/case statement. The graph view should show us the path the program is going down, and if we can alter it.
Postby gruntly69 » Tue Jul 31, 2012 9:57 pm
Just to follow up on this 1 Dave, do you still have the plastic security card with all the original details for this car?
If so it should have the BCM security code on that & I can give you the details 2morro once I'm at workshop & if you can confirm for me it would be great!
gruntly69
Postby gruntly69 » Wed Aug 01, 2012 6:18 pm
Did a bit of testing with my snap-on MT2500 scan tool today & it seems to send out more information than a car as this was on a bench & only BCM connected hence fault codes in BCM!
Interesting all the same with info for messages sent!
gruntly69
  • In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 18 guests
