4T65-E Transmission Specifications
Type:
4T65-E Transaxle
Four speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch
Engine Range: 2.5L - 3.8L
Maximum Engine Torque: 280 lb-ft (380 Nm)
Maximum Gearbox Torque: 400 lb-ft (542 Nm)
Gear Ratios:
First: 2.921
Second: 1.568
Third: 1.000
Fourth: 0.705
Reverse: 2.385
Maximum Shift Speed:
1-2 6500 rpm:
2-3 6250 rpm:
3-4 6000 rpm:
Maximum Validated Gross Vehicle Weight: 2903 kg (6400 lb)
7-Position Quadrant: P, R, N, OD, 3, 2, 1
Transfer Design: Two-Axis design, link chain assembly
Case Material: Die cast aluminum
Assembly Site: Warren, MI
