by silversv6 » Wed Jul 31, 2013 11:45 pm
you could try a screen printer, who make coreflute signs such as real estate signs & banners. They can print onto plastic as they use solvent inks. Also, a screen printer will have to make several different screens which would be fairly expensive. The other option may be a sign shop with a good digital printer (print & cut machine) & print it onto vinyl & then you can stick it on. They can print onto a wide range of plastics, vinyls, fabrics ect. Must be a solvent ink, not a pigment ink like in a normal printer. Pigment ink will not dry on plastic metal etc. Any sign shop with a machine such as a Roland Soljet eco sol can print directly onto most plastics upto about 6mm thick.
hope this helps you.
PS. They can print (sign shop) it onto lightbox vinyl which will allow the lighting to come through where you need it to & block where lighting is not needed. Printed in reverse then stuck on the back of your new piece of plastic is better for back lit applications Cheers
