Tech 2 RS-232 adpater pinout
Postby radrace19 » Wed Mar 06, 2013 8:48 am
Looking to update a friends Tech 2, but he doesn't have the DB9 to RJ-45 adapter and cable.
Does anyone know if the cable is a crossover cable or a standard patch cable?
Does anyone have the pinouts for the adapter?
Thanks,
Greg
2009 G8 GXP
586 rwhp - LS3, Cam, TVS2300
radrace19
Postby doubledip » Wed Mar 06, 2013 10:35 am
straight through not cross over
Postby radrace19 » Wed Mar 06, 2013 12:54 pm
Actually I found this pinout:
DB9 pin 1 = RJ45 pin 2
DB9 pin 2 = RJ45 pin 4
DB9 pin 3 = RJ45 pin 5
DB9 pin 4 = RJ45 pin 8
DB9 pin 5 = RJ45 pin 7
DB9 pin 6 = RJ45 pin 1
DB9 pin 7 = RJ45 pin 3
DB9 pin 8 = RJ45 pin 6
DB9 pin 9 = NOT USED
I wired a DB9 connector up to a RJ45 port. It did not work with a straight cable so I used a crossover cable and it is now updating.
-Greg
2009 G8 GXP
radrace19
Postby doubledip » Wed Mar 06, 2013 1:50 pm
its a straight cable... it normally plugs into a rj45 to db9 adapter... in there is the crossover you are experiencing
but the cable is straight through :)
Postby beerman » Fri Apr 12, 2013 10:28 am
here you go
beerman
Postby radrace19 » Sat Apr 13, 2013 3:19 am
Thanks.
I ended up changing up my adapter wires to use a standard patch cable instead of having to dig for a crossover cable weeks ago.
I just never updated my chart.
-Greg
2009 G8 GXP
radrace19
  • In total there are 32 users online :: 0 registered, 0 hidden and 32 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 32 guests
